Need help to make AFS work
All the headlight gurus out there, I really need your help on how to make the AFS option work on a non AFS equipped vehicle. I have a 06 IS250 with the halogen projectors. I just purchased a set of projectors with AFS motors and ballast
I also found this on ebay, it is a OEM HID wire harness for the 2IS
What else would I need to make it work? I chose to retro these projectors because of how the headlight bulb is plugged into the projectors ( On the side of the projector rather than the rear) Like so:
This is a halogen headlight, but you can see on the left side that the bulb goes in from the side. Any input on this would be greatly appreciated. Thanks.
exclusive matchup
honestly i say forget it, it's just way too hard. i mean, you can't even get normal autoleveling to work, since it has sensors on the wheels and unless you spend a lot of hours putting wires and more parts, it's not gonna fly.
and adaptive headlights with left and right movement, i am sure it involves even more sensors with steering and what not. that's way too much trouble
