DIY GS Retrofit Instructions
Does anybody have any detailed instructions on how to do your own retrofit? I thought I had seem some around here, but I can't seem to find anything when I do a search.
Very cool. Jeff does good work, so hopefully I can follow these instructions. Are there any other ones out there? I still haven't decided what projector to use. I got a set of OEM HID lights ready to go just for this project.
Does anybody have instructions on how to remove the bumper on the GS, or how to remove the headlights without removing the bumper?
Also, how do I rewire my headlights to work with an HID assembly. I currently have the NON HID headlights on my car. Thanks!
Which one do I need, and what option? http://www.xenondepot.com/category.php?category_id=9
http://sr1.clublexus.com/forums/showthread.php?t=264551
Or you can to buy the OEM ballast and look for the new bulbs. Thats what i did on my car. you are looking for around 220-300.
Good luck
Its depend on how much you want to pay? i installed my friend's IS 250 the Extreme like this a link below, but i believed the promotion just expired.
Good luck
Good luck
Any other sites or links on how to remove the 98-05 GS headlights without removing the front bumper? Banana's site is down so I dont know where else to find them and I already searched.
It's not hard to remove the bumper. I did it numerous times when i was working on my turbo.
There are 2 10mm screws on each side that are accessible through the wheel well. Unscrew the fogs, disconnect the bulbs. Then you have 2 screws near the headlights on each side and your almost done. Go underneath and pop off all the plastic bolts holding the cover underneath. I believe that was it. I'm going off of memory here.
Its not that hard takes about 15-20 mins tops. You do need a long ratchet extension though.
I also did the NON-HID to HID conversion, but I used heavy duty harness wires with relays to power the ballast. If you know basic wiring it should be a piece of cake.
