LX470 - Projector retrofit to allow for Bi-Xenon...HELP!
Sup guys...dont venture into the lighting section much but, im sick of not being able to see farther ahead of me on the dark curvy parkways. I used to have huge offroad rallye lights on a pushbar on the front of my truck, was fun, blinded the crap out of people and lit up the NJ Turnpike for over 3/4 of a mile. Anyways, once i got my HID PnP kit from XD for the lowbeams, ive since taken them off and sold them.
Well, i moved now and the parkway i use now has no overhead lighting and is much more windy then I-95. I was thinking about doing HIDs in the highs, but with all the On/Off for oncoming drivers, they prob wont get up to temp and will most likely prematurely blow out.
I was thinking of doing a retrofit of some bi-xenons into the low beam housing to allow for more light on demand. Been in a GL450 and a new 911 turbo that had the Bi-Xenons and what a difference in high beam output in comparison.
so without further delay...
Does anyone know a reputable source to get a retrofit done? Be it a CL member, company in cali, whatever, i just want the job done right. Does anyone have an idea for me? I can post pictures of the room i have to work with behind the light housings, the driver side might be tight due to the battery, passanger side is clear since i have an intake kit.
PS:I wouldnt mind doing a bi-xenon retro for my foglights instead using a hi/lo projector and putting HIDs in there, if room was limited for the regular low beam location. That way i could run 4 hid low beams and then have the fogs switch to highbeam HID when the stock high beam halogens come on.
not bi-xenon, im prettttty sure its just HID projectors. Either way, he can play with my lights if he wants, he goes a good job.
If you are going to go through the whole retrofit thing then i suggest going with Porsche Bi-xenons found in the new Cayanne (sp?). THey are made by stanley/koito, same company that has made projectors for S2000, LS430, TL, TSX etc etc so the best of the best shall i say. I am sure there is plenty of room in the back for you to squeeze one of these bad boys. Here is what they look like.
![](https://i144.photobucket.com/albums/r161/rjph/DSC00257.jpg)
They have awesome width and a great hi-beam. The best bi-xenon present in the market right now is out of the 04+ Acura TL but i doubt that it will fit in the LX headlights thats why I suggest going with these
05-12-15 01:44 PM
