Q45 multireflector installation (how we do in Japan) lots of pics
DONT ASK ME ANY QUESTIONS.
I HAVE NOT DONE THIS AND JUST POSTING UP TO HELP MEMBERS WHO MIGHT BE PURSUING THIS PROJECT.
and with that said, the next person to PM me questions about this will get a picture of my cats poop as a reply.
I found an old DIY write up by ClubAristo. I never got around doing it, but it was pretty informative so I thought I'd translate some of it, and post it here.
you'll need to install Japanese text to open up the pdf files (CAD drawings).
I'm just simply sharing this as resource. Don't ask me for translation, how-tos, or anything like that. And of course, do this mod at your own risk.
With that said, here's a magnificent write up by ClubAristo...
![](http://www.asahi-net.or.jp/~ge8w-ngkw/mente/jpg/297-03.jpg)
Q45 20mm multi-projector headlight unit
![](http://www.asahi-net.or.jp/~ge8w-ngkw/mente/jpg/297-04.jpg)
on the front it says "Multi-lens: Made in Germany"
on the back it says "Gatling Beam"
woot, Gatling guns..I mean headlights from Germany.
![](http://www.asahi-net.or.jp/~ge8w-ngkw/mente/jpg/297-05.jpg)
side view
![](http://www.asahi-net.or.jp/~ge8w-ngkw/mente/jpg/297-06.jpg)
aluminum heatshield and stay
![](http://www.asahi-net.or.jp/~ge8w-ngkw/mente/jpg/297-07.jpg)
plastic with chromed reflector
![](http://www.asahi-net.or.jp/~ge8w-ngkw/mente/jpg/297-08.jpg)
![](http://www.asahi-net.or.jp/~ge8w-ngkw/mente/jpg/297-09.jpg)
lens removed from housing
the lens are glass
![](http://www.asahi-net.or.jp/~ge8w-ngkw/mente/jpg/297-10.jpg)
housing unit
![](http://www.asahi-net.or.jp/~ge8w-ngkw/mente/jpg/297-12.jpg)
take apart clear cover and headlight unit.
![](http://www.asahi-net.or.jp/~ge8w-ngkw/mente/jpg/297-13.jpg)
modded housing to fit lens
side view
the lens are glass
housing unit
![](http://www.asahi-net.or.jp/~ge8w-ngkw/mente/jpg/297-14.jpg)
reflectors painted with BNR32 OEM paint "gun metallic KH2" but with chrome left for turn signals
cleared out turn signals
![](http://www.asahi-net.or.jp/~ge8w-ngkw/mente/jpg/297-15.jpg)
reflector with HID burner
units held at 3 places
top two are held with a bolt to adjust up/down left/right
the bottom one connects to the auto-leveling connector
be careful not to break the tab
![](http://www.asahi-net.or.jp/~ge8w-ngkw/mente/jpg/297-16.jpg)
auto leveling motor
![](http://www.asahi-net.or.jp/~ge8w-ngkw/mente/jpg/297-17.jpg)
![](http://www.asahi-net.or.jp/~ge8w-ngkw/mente/jpg/297-18.jpg)
chromed housing
------------creation of the back place--------------------
![](http://www.asahi-net.or.jp/~ge8w-ngkw/mente/jpg/297-plate.gif)
http://www.asahi-net.or.jp/~ge8w-ngk.../297-plate.pdf
1.5mm stainless (SUS304)
same for both sides
http://www.asahi-net.or.jp/~ge8w-ngk...297-stay01.pdf
plate to hold backplate, "stay-A"
![](http://www.asahi-net.or.jp/~ge8w-ngkw/mente/jpg/297-stay02.gif)
http://www.asahi-net.or.jp/~ge8w-ngk...297-stay02.pdf
plate to hold backplate "stay-B", "stay ring A/B"
![](http://www.asahi-net.or.jp/~ge8w-ngkw/mente/jpg/297-stay03.gif)
plate to hold backplate C1/C2
allows autoleveling (movement of 38-46mm)
C1 is right/left specific
C2 is the same for both sides
![](http://www.asahi-net.or.jp/~ge8w-ngkw/mente/jpg/297-19.jpg)
laser cut backplates and stays
backplate has a carbonfiber decal on it
![](http://www.asahi-net.or.jp/~ge8w-ngkw/mente/jpg/297-20.jpg)
backplate+lens
make sure to put something on so the scews wont come off from vibration
![](http://www.asahi-net.or.jp/~ge8w-ngkw/mente/jpg/297-21.jpg)
back view
![](http://www.asahi-net.or.jp/~ge8w-ngkw/mente/jpg/297-22.jpg)
Toyota headlight unit and Nissan multireflector headlight
![](http://www.asahi-net.or.jp/~ge8w-ngkw/mente/jpg/297-23.jpg)
extended with PCV pipe to allow clearance for HID connectors
![](http://www.asahi-net.or.jp/~ge8w-ngkw/mente/jpg/297-24.jpg)
pipe covered to protect from water and whatnot
![](http://www.asahi-net.or.jp/~ge8w-ngkw/mente/jpg/297-25.jpg)
![](http://www.asahi-net.or.jp/~ge8w-ngkw/mente/jpg/297-26.jpg)
![](http://www.asahi-net.or.jp/~ge8w-ngkw/mente/jpg/297-30.jpg)
small position light (JDM daylight running lights)
![](http://www.asahi-net.or.jp/~ge8w-ngkw/mente/jpg/297-31.jpg)
finished product
props to ClubAristo
does the auto leveling still works? on these leds?
beam, gatling, gs300, headlight, headlights, installation, led, light, ls430, multireflector, projector, projectors, q45, side, view, work
