RX xenon lights are more blueish than IS
Old 06-23-07, 11:41 AM
Axvel
Axvel's Avatar
Default RX xenon lights are more blueish than IS
I have a 2006 is350, i took it for service and they gave me an 2008 RX350, why is the xenon lights on it more blueish than on the IS?
Can i just buy the bulbs and exchange them from the RX are they compatible?
The Rx's look more like the benz or the bmw...it's what i want
Old 06-23-07, 11:43 AM
BaLLzZz
BaLLzZz's Avatar
lol yup i have an rx in the family and it always usto get me annoyed but i kno the tech and i made him level my xexons upmore it helps out a little.
Old 06-23-07, 11:46 AM
Axvel
Axvel's Avatar
so if you level them up a bit they have a more bluish tones to it? But the seem more brighter and stronger too.
Old 06-23-07, 11:50 AM
cspec
cspec's Avatar
Change to 6000K D4S bulbs mang
Old 06-23-07, 11:54 AM
BaLLzZz
BaLLzZz's Avatar
I also concluded that the rx lights are a little more advanced and if not technically it just seems that way. Now anyone who has been in both cars can attest to this. Start an rx against a wall and watch the lights dance left right up down but really wide. Now start your isx50 and up and down but left and right nothing liek the rx. Also the rx sits higher so the lights your seeing are moreso at eye level. Get on the floor infront your isx50 and look directly at the lights you will see the blue you want so just if you can try and make a tech turn them up a bit. It worked out for me but if you still are not happy just get the bulb.
Old 06-23-07, 12:37 PM
T4styPh0
T4styPh0's Avatar
Is it just me or does 6000k flicker colors more than the stock 4300k? Because I have 6000k and it seems that way.
Old 06-23-07, 01:25 PM
ULTiMaX99
ULTiMaX99's Avatar
i'm pretty sure the rx uses the same or similar temp hid bulbs as the is. the blue cutoff that you see is created by the projector housing. if you want that cool blue/purple cutoff/flicker, you'll need to alter the projector housing. not sure if it has been done to the is yet, but people have done it for other cars like the tsx by adding washers to push the projector lens out more.
Old 06-23-07, 01:28 PM
cspec
cspec's Avatar
No, it's because the different type of bulbs that the RX uses.
Old 06-23-07, 01:37 PM
T4styPh0
T4styPh0's Avatar
Oh, I thought they use D4 also.
Old 06-23-07, 01:46 PM
Axvel
Axvel's Avatar
so basically will the rx bulb work on is?
Old 06-23-07, 02:01 PM
T4styPh0
T4styPh0's Avatar
I just checked on sylvania and RX uses D2 so no it wouldn't work.
Old 06-23-07, 02:40 PM
SilverBull
SilverBull's Avatar
I just bought a 08 RX350 for my wife to replace my Acura TL-s. I like it a lot and the lights seem normal to me. However, I didn't get HID lights with my IS. I added 8,000k lights to them later on so both look nice. I think the aftermarket lights look better honestly.
Old 06-24-07, 08:22 AM
r1lee
r1lee's Avatar
I believe the projectors in the IS and the RX are the same. I couldn't or would not believe LEXUS going with two different types of projectors, especially since cutting costs is the main objective. Most of the time, you can relate blue/purple projection lights to the projector.
In the case, i also do think it's the type of bulb and the angle both cars are at. The IS uses the mercury free D4S. Actually Wikipedia even says the mercury-free bulbs produce more of a white light, then the older mercury ones. Read under "Construction - Types of HID lamps included:"
http://en.wikipedia.org/wiki/High-in...discharge_lamp
Old 06-24-07, 10:55 AM
NovaIS350
NovaIS350's Avatar
thats because the IS has a newer bulb design. It is a mercury free bulb. D4S vs D2S. The lights on the RX may look more blue, but the lights on the IS are brighter.
EDIT: Just read the post above mine, 100% correct.
Old 06-24-07, 11:08 AM
ben_r_
ben_r_'s Avatar
Yea I was driving at around dusk a few days ago and saw one drive past and thought the same thing! The RXs does look better than ours.
Quick Reply: RX xenon lights are more blueish than IS
