A couple of quick questions, The conversion kits do they just screw into your stock housing? And I have heard that you loose your high beams when going to hid. Is this true?
huerdo - yes, the kits just plug and play into your system. and more than likely you will not lose your high beams unless your headlight bulb is a dual purpose bulb for both high and low.
Um, I think 92-94 are good (mine's is a 92 and I aimed it real low so it wouldn't glare and blind people as much). But I think 95-96 are gonna be a little different.
