Mercedes Bixenon retrofit?
Hi
I have a 92 SC400 and I was wondering if the HIDs (BiXenon) found on 2005and up Mercedes C-class will fit on my headlights with some modification?
Thanks.
Thanks.
jess, since you said the e46, that means the e46 bi-xenon correct? those seems like they should fit but are a little long on the bulb end right? heres a link to what i plan on getting. btw, its for a 98 sc300 and do you have the adapter plate for these?
http://cgi.ebay.com/ebaymotors/ws/eB....cWAT.m240.lVI
No, he means e46 bosch projectors. Why do you need bixenon when your high beam is independent of your low beam? Anyways, Im selling my set up since I sold my car.
https://www.clublexus.com/forums/sho...d.php?t=313153
not trying to thread jack, but im sure i want it done for the same reason jeslet wants it, more lighting for high beam is always a plus. why not? high beams will only be on if i need it and when nobody is in front of me. dual highbeam would be better than oem highbeam.
I went with TSX retro.. it's a PITA, don't try it.
