Can aftermarket bulbs be used with factory ignitor?
I have a d2s kit off a gs430 with rebased 9006 4100k bulbs. One of the bases came off and wont stay in the socket. Plus the whole set up was a pain to keep locked in the hid socket and in the headlight socket. THey turned opposite ways, meaning had to turn the bulb 1 way to lock in the ignitor socket and then turn the opposite way to lock in the headlight. So they usually came loose or fell out the headlight Now my question is, can i cut off the d2s socket and buy some aftermarket hid bulbs and connect positive and neg wires and be on my way? Only thing is that I see the red (pwr) white (neg) and then 2 little green ones??? Would those be a ground or something? However aftermarket ones have just 2 wires
Why not just buy an after market re-based 9006 D2R bulb? If the set you have is OEM and came of a 2nd gen GS430 is should be D2R anyway. Either way, the ballast can work with D2R/S. There are many 9006 based D2R/S bulbs available. I'd rather used one of those than buy other after market ones with the wires already attached and try to retrofit or splice it into an OEM style ballast.
