Looking to purchase HID's for my SC400
Does anyone know where I can get some good HID's for my 93 SC400? I am leaning more toward 6000K. I don't want to get a brand that has a lot of glare though, so does anyone know which one to get that has the less glare possible? My stock lights are very dim when driving at night and I see all these other vehicles on the road where their lights light up the whole ground in front of them and is PURE white instead of ugly yellow. I just want that. Any help would be appreciated.
A wee bit of edu-maca-shun.
Mandatory Reading
http://www.hidplanet.com/forums/viewtopic.php?t=2080
Everything Else
http://faqlight.carpassion.info/
Mandatory Reading
Everything Else
vntperform has a kit for sale for $185. I bought a set, and it turned out nicely. No glare or anything like that, and it was definitely a + compared to the stock bulbs. Shoot him a PM, they're the 9006 bulbs, so no retrofit required. 6000K looks great.
I am posting these images that hakandslash posted on SRT-4 forums, in response to people asking for PNP kits. Hak, if you want me to remove these pics, and just provide a link, then that is fine. I just couldn't illiterate the subject like you can.
Your typical PNP kit.
Your ECE retro!
I hope this has helped!
Those pictures are really helpful to see the difference between setups. I'm not a big person on lighting or HID so I'm not an expert on what works the best. I got my kit with 6000K and it's considerably brighter than when I had my stock halogens as well as when I upgraded to the Sylverstar brand before going HID. I'm still getting to know more information on the whole HID lighting and the different setups, so it wouldn't be surprising if I ended up changing bulbs down the road.
HID kits may seem the easy way to get HIDs in your car but trust me you are better off sticking with halogens rather than 50~300 dollars on a PnP kit.
If you really want HIDs then do a retrofit using OEM HID projectors such as TSX, S2000 etc.
HID kits FTMFL.
If you're still looking to upgrade your headlights, I have some Audi TT/E46 projectors also known as bosch projectors that you can retrofit into your SC headlights. I also have the brackets and shroud that will make the projectors look completely stock.
https://www.clublexus.com/forums/sho...=Audi+retrofit
You can locate TSX projectors,a set of ballast and bulbs on ebay for right around 300-325 on ebay..You can also make the retro easier with custom aluminum SC headlight retro brackets..Once you have all the parts the whole process will take about 2 hours and you will have much better look and light output..I was going to do the PnP kit and decided that a retro would be the better way to go ..
