cahnge the bulb won't do anything, unless you put in very high unsafe wattage bulb like 100w or so. but forget about using high beam coz' you will see smoke very soon
you can use a relay and run full power on drl, but that's very bad coz' you will be glaring all traffic.
just stay with the current setup, they are "dim" like that for a reason...
Im guessing he wants a whiter light output. I'm guessing he may be interested in installing some blue tinted bulbs.
thanks GordoNx3o9, I'll check ebay out. Is there a specific bulb # that I need to look for? Sorry, but I'm not sure what to look for. Thanks in advance.
hey i just slaped on some 1w led lights to replace the oem bulb now my drl wont turn on. Do i have to do anything to get them to work again. But when i hit the high beam switch they work.
