WTB ls430 projectors.
LS460 and LS430 are totally different projectors. BTW LS430>LS460 by eons. Here is a comparison post i made a while ago on HIDplanet. I didnt post direct images since there are 27 of them and CL only allows 10 in one post.
Originally Posted by JnC
Turns out that the LS460 projectors are not as bad as most of us thought. They compare very well to the S2ks as far as intensity is considered. On a scale of 1-10 where 10 is best with both intensity and width. I would rate LS430s at 10, S2ks at 8 (only missing out on width) and LS460s at 7.5. The bottom reflector bowl actually doesnt throw light out to the side alone, it takes the light and fills up the spots where the projector lacks intensity..
I have shown one picture where the projector is covered and you can only see the output of the reflector bowl and notice how it throws light all around unlike the LS430s which only throws light towards onside to increase width. LS460s are S2k wide not LS430 wide but they have great intensity. Also, ZKW is a drop in but the focal length is less than the OEM LS460 lens. I also tried the clear 3"~ lens that i got from zam and it not only is it too big for the LS460 but also lacks the focal length, So for now there is no clear lens drop in that would work for this projector. Lets just say that what ever works for the Prosche Bi-xenons the same lens would work for LS460 since they both have almost the same focal length.
The three lenses in question, from left to right, first one is the ZKW clear lens, 2nd one is the OEM LS 460 lens and lastly it’s the clear lens from zam2000.
http://maxupload.com/img/B0EA1F0D.jpg
ZKW
http://maxupload.com/img/61FADF45.jpg
LS 460 lens, notice the roughed surface around the outer edge of the lens reminiscent of the S2k lens.
http://maxupload.com/img/13E1F954.jpg
Clear 3” lens from Zam.
http://maxupload.com/img/CE6BEB5A.jpg
ZKW yet again.
http://maxupload.com/img/EC8030FB.jpg
http://maxupload.com/img/71A3C869.jpg
LS 460
http://maxupload.com/img/DF7DA12F.jpg
http://maxupload.com/img/A6685941.jpg
Zam’s lens.
http://maxupload.com/img/91F37783.jpg
Output Shots
All projectors rested at the same spot pointing the same direction. I used an old 85122 bulb which i modified to fit the LS460 since it takes D4s bulb. This way it would be easy to judge the intensity in a comparitive sense of each projector.
LS460
This is the right hand side projector, LS460 projectors are side specific as well just like the LS430.
Light towards the right, notice the spread.
http://maxupload.com/img/E06174C9.jpg
http://maxupload.com/img/3192C404.jpg
The LS460 has ECE cut off
http://maxupload.com/img/8730BA24.jpg
Light towards the left, not bad.
http://maxupload.com/img/9C9E6382.jpg
The following couple of pictures show the output of LS460 projector with the projector lens covered. This is light that comes out of the bottom reflector bowl, notice that its not just thrown to one side like the LS430. The bowl throws patchs of light at different spots to increase the intensity of the overall beam.
http://maxupload.com/img/5FE19B77.jpg
http://maxupload.com/img/009C475A.jpg
http://maxupload.com/img/FDD093B6.jpg
This is what the LS460 looks like with the ZKW lens, not pretty.
http://maxupload.com/img/012DFD82.jpg
AP2 S2000
http://maxupload.com/img/A8A4B95B.jpg
http://maxupload.com/img/C06ED449.jpg
http://maxupload.com/img/2515BCC5.jpg
http://maxupload.com/img/312A527A.jpg
LS 430 (right)
http://maxupload.com/img/0DA021EC.jpg
http://maxupload.com/img/9800492B.jpg
http://maxupload.com/img/79033EA9.jpg
http://maxupload.com/img/ED1ABEF2.jpg
ZKW
ZKW yet again.
LS 460
Zam’s lens.
Output Shots
LS460
AP2 S2000
LS 430 (right)
4eign
12-26-11 01:59 PM
