c2ispy -- Valeo HID retrofit full-writeup --
Old 12-09-07, 03:30 AM
c2ispy
c2ispy's Avatar
Originally Posted by JesLet
Stock brackets huh? Let see what you can do
I think it will be easier if you make your own. Like this:
Unfortunately, this 3" valeo wont cooperate with me.. I already trimmed some of the edges just to get the damn thing to fit. I have some lexan laying around.. unless you want to make me some mounts
Old 12-09-07, 04:35 AM
c2ispy
c2ispy's Avatar
Thanks JesLet for the inspiring picture... I just mocked up some brackets on paper, just got to wait to get it cut tomorrow. I left my camera in the car so updated pictures will be up tomorrow.
Old 12-09-07, 05:05 AM
JesLet
JesLet's Avatar
Hey man I just noticed you're from HI. I went Oahu months ago, love it! I should have stayed there and never went back to isshhole AZ.
By the way, are you going to use plexiglass for bracket? I think it's not that good.
Old 12-09-07, 05:15 AM
c2ispy
c2ispy's Avatar
Yeah, I'm going to use lexan..Did you have a bad experience with plexi-glass? The shop I bought it from makes signs and light panels for all the major hotels on Oahu. He said the material that im using (lexan) is pretty heat resistant and it can resist chips. Im going to take it to him to get my cuts done and see what he says. As for the PM you sent me, I dont think we have a cnc shop thats open to the public.
I'm actually a tour-guide on O'ahu! Haha, good to see you loved your visit. I actually have a friend in Tucson thats visiting in late Dec.
Old 12-09-07, 05:31 AM
JesLet
JesLet's Avatar
No, I didn't even try the plexis, I actualy bought aluminum sheets from Dome Hepot. They are kinda thin but I made 2 pairs for support. I don't know anything about Lexan...you can try. But my concern about plexis or lexan is once you got the pattern or bracket trimmed the thin sides might crack during installation and leveling the headlight's beam.
Tucson is like the opposite of Oahu ha ha. I stayed in Hilton rainbow tower. I love the place I love the people.
Attached Thumbnails c2ispy -- Valeo HID retrofit full-writeup ---retrofit-2011.jpg
Old 12-09-07, 06:01 AM
c2ispy
c2ispy's Avatar
the lexan im using is 1/4 inch thick.. or 3/8 so im just going to hope for the best.
Old 12-09-07, 10:57 PM
c2ispy
c2ispy's Avatar
Ok, so its been two days since my past update. I've made some progress even though im swamped with HW and work. First off, I yanked my headlights off, baked them, and took them apart. To learn how to bake/take your headlamps apart, click here .
The 3" valeo is rather large and its almost the same size as the stock projector. Why the valeo? I chose it because I liked the cutoff and output from projectors that cost only $60 bucks.
To get the projector to sit properly in the OEM housing, you need to trim off the top left mounting tab diagonally:
Before:
After:
Did some test fitting:
I used the OEM 3" bezel, and it fits like a charm!
Ok next off is the mounting bracket. I took Jeslet's idea and ran with it. What I did for my bracket was.. I took a piece of aluminum wire, and wrapped it around the bowl of the projector:
Now that you have an almost exact shape of the bowl, you want to trace the OEM bracket onto your medium of choice. In my case, I chose Lexan; a stronger, denser, version of plexi-glass. Once you've traced your OEM mounting bracket onto your material, take the piece of wire that you shaped around your bowl earlier, and place it strategically in the center of your tracing of your bracket:
Once you got everything eye-balled, get your cutting tool: dremel, rotozip, etc, and cutout the necessary holes and extra material that might cause fitment issues inside your stock housing. I'll have more pictures of that tomorrow when I get my templates cut
Heres a picture of my template.. its not the greatest, but i made it in 3 minutes:
If you have any tips or advice for a newbie like me.. please chime in.. BTW this is my first time attempting a headlamp retro
Chris
Old 12-10-07, 12:05 AM
chrispy
chrispy's Avatar
What kind of bit or blade are you using to cut the lexan? I tried a dremel drill bit but it tends to melt the plastic if you go too fast.
Old 12-10-07, 12:18 AM
c2ispy
c2ispy's Avatar
I'm going to use a jigsaw.. I have a orbital jig so it can do most of the curves and circles. I'm going to do some test cuts on some scraps, and if it does melt, then I'll take it to the shop I bought it from since they have the facilities to cut this material properly.
Old 12-10-07, 10:44 PM
c2ispy
c2ispy's Avatar
So I cutout my template with my rotozip. I recommend practicing on scraps unless you are pretty crafty with the rotozip/dremel already.
Heres my somewhat finalized template.. The circle on the bottom right and the three mounting whole still need adjusting but thats minor. I got the hard part done and it took me about 2-3 templates before I got it right. This lexan is DAMN STRONG! If you try to bend it, it doesnt chip it just bends, thats the good thing about lexan.
I got the plastic retainers in place and ready to bolt in.
And.. a little test fitting...
the other side will be cut out when I am happy with the fitment of the prototype. So far, I rate this retrofit a 6/10 difficulty wise. Stay tuned for more updates with my newby retrofitting
Old 12-10-07, 10:51 PM
LXMN
LXMN's Avatar
The dremel should work fine. I have the XPR with all attachments. You can use the grinding bits to fine tune your rough cuts. If you have the saw attachment, that would work for the center cutout with the plastic clamped down. I used this attachment to cut a hole in my kitchen counter for my sink to drop in. So you know it's a quality tool that can handle a project.
Old 12-10-07, 10:54 PM
c2ispy
c2ispy's Avatar
I just did this tonight with a router bit and I got fantastic results for freehand cutting. It starts to melt if you hold it in one area for a long time. But if you follow your lines quickly melting shouldn't be a problem.
Old 12-10-07, 10:55 PM
c2ispy
c2ispy's Avatar
Damn, I'm so anxious to cut the other side and slap these puppies in but its late and my rotozip sounds like a damn bike hitting 15k rpms
Old 12-11-07, 12:49 AM
ACleanSC4
ACleanSC4's Avatar
I like everything but your bracket. I don't see that being a sturdy piece in the long run. Maybe a machine shop with a water jet can put your template into aluminum and not cost an arm & a leg...
Regardless, congrats on doing a retro, can't wait to see it finished!
Old 12-11-07, 12:55 AM
Caoboy
Caoboy's Avatar
A straight edge and compass would work a bit better than freehand. Looking good though.
Quick Reply: c2ispy -- Valeo HID retrofit full-writeup --
