Finally put my 6000k HID kit in my gs.... and problem
You have yellow glass caps my friend. No matter what kelvin bulb you buy, you are going to get a ton of yellow in your output.
You have to swap in some GS400 fogs that aren't yellow, then you will have your true 6K color.
Good luck and be safe!
BTW, Welcome to the boards VIS250P! I haven't seen any of your posts before, yet you have 255! Where have I been?
![Frown](https://www.clublexus.com/forums/images/smilies/frown.gif)
I didn't do it myself so I wouldn't know that's why I was asking when I lit up the bulb I had just hooked up the harness to the battery to see if it worked
There are two screws holding each fog lights. They are each located nearest to the center of the bumper on the fog light housing. You cant miss it. Just unscrew it and pull it out. Be sure to unclip your HID bulbs and store them in the plastic protective tube it came in. DO NOT touch the bulb.
