Problems with a TSX retrofit purchased used..
from another clublexus member. I didn't expect it to be pristine as I was able to negotiate the price down to $250. But I didn't realize how bad the headlights were until it started to rain here in Cali. I was able to reseal one of the headlights to keep all moisture out on the drivers side but I could not on the passenger side headlight. The reason that the passenger headlight didn't seal properly is because it appears that the housing was taken from a crashed SC. The whole right side of the headlight was fiberglassed and was missing one of the mounts. I'm guessing that water is seeping in through the fiberglass and collecting inside. I took it apart and saw that there was extensive damage to the plastic housing all over.
Now I've done about 20+ S2000 headlamp modifications so I do have a little bit of experience opening and resealing headlamps. But the damage is pretty bad so I am thinking of just transplanting the TSX projectors to my good stock passenger headlamp.
The person who did the retrofit on the ones I bought did a kind of hackjob and did not make a good bracket, he just ziptied the TSX projector to what appears to be a cut up stock SC projector bowl. I'd like to do a proper job with a good bracket instead of transplanting the hackjob.
My question is, does anyone have a bracket template or better yet, have access to a person who can make the metal brackets for me? I am willing to pay a reasonable amount to have a pair made.
Sorry for the long winded post, but I just thought that I'd give a little history to cut down on any questions people might post.
Update: Purchased brackets and photos of transplant with new brackets down at the bottom
You my friend, are in the same boat as i am (bracket wise) lol
If you buy the pair of brackets from Tony can you go to a machine shop and see if they can make a copy and get a price? I need them to finish my retro also.
Goodluck!
Goodluck!
Mortgage Slave
Ahh that sucks to hear. I'm in the middle of doing a retrofit myself too (RX330). Just a question, how long do you leave the headlights in the oven for? I left the RX330 lights in for 6 minutes and one was easy to pull apart and the other was ***.
Ok an update to this thread. I finally met up with Tony (ACleanSC) to purchase the brackets, big thank you to him! And after much hemmin and hawing, I finally cracked open the botched headlamps and retrofitted them into my good stock housings. Well here are the results after 3+ hrs of fitting, cutting, and cleaning up the other guys work. I can tell that life would've been easier if I had just done it myself from the beginning.
Here's the original, work was very hackjob and sloppy, not to mention extremely leaky. First rains turned those headlamps into aquariums. Notice how far back the projectors sit. This is because he didn't use any brackets, just JB welded the plastic adjusting screw clips to the TSX housings.
![](https://img.photobucket.com/albums/v621/dougspeed/1992%20SC400/sc400hid.jpg)
And here are some photos I took after cleaning the projector housing up and fitting it to my original housings.
Bracket
![](https://img.photobucket.com/albums/v621/dougspeed/1992%20SC400/bracket.jpg)
Fitting
![](https://img.photobucket.com/albums/v621/dougspeed/1992%20SC400/fitting.jpg)
![](https://img.photobucket.com/albums/v621/dougspeed/1992%20SC400/projectorandbracket.jpg)
![](https://img.photobucket.com/albums/v621/dougspeed/1992%20SC400/projectorandbracket2.jpg)
![](https://img.photobucket.com/albums/v621/dougspeed/1992%20SC400/headlampdisassembled.jpg)
Final result
![](https://img.photobucket.com/albums/v621/dougspeed/1992%20SC400/headlampassembled.jpg)
Bracket
Fitting
Final result
![](https://img.photobucket.com/albums/v621/dougspeed/1992%20SC400/headlampassembled2.jpg)
Nice job bro! My TSX projectors is sitting farback unlike yours. I should have bought a bracket something like that.
I don't feel like reopening the healights because it is a PITA.
Do you have more pictures of the back of the headlamps? I want to see how did you cover the bulbs.
Hah, I'm still trying to figure that part out. The other guy used fiberglass and custom made a cover for it, but it was glued to the housing so I couldn't move it to my new housings. Not sure what I'm going to use to cover them right now.
As for the brackets, I got em from Tony since he had an extra set for what he paid, $50.
