Bosch HID Kit! W/ PICS***
Whats up guys, I just bought a BOSCH HID KIT Generation IV and they seem really high quality since phillips is their parent company to my knowledge. Anyways... I believe these are plug and play but i am confused about the installation. I have no information on the install; none came with the kit. Everything looks simple but i don't understand the whole "grounding the kit".
As far as mounting my ballasts, where do you guys suggest? I have an SC400 btw. I understand the cables aren't too long so they will have to be mounted close to the headlight housing. But is mounting the ballast considered grounding them? Sorry i have very little knowledge on this information about HIDs.
Thanks Everyone!
Pictures are here too.
Thanks Everyone!
These appear to be powered off your stock harness. I would suggest adding a relay and powering it directly off your battery. There would be your grounding as well.
For the ballast, you can use some 3M tape and tape the passenger side to the front of the airbox. Driver side you can tape to the sides of the battery. If they are longer, you can hide them away on the front bumper beam.
Good luck!
Good luck!
Today i tried installing them, i didn't think about 3M tape. Also the stock harness did not power them up, so how would i go about adding a relay? I thought this would be easier then how it is turning out to be. If there is a DIY please refer me to that. Actually guys i think i got the main idea of it. Its just the soldering and stuff that is confusing. Like when i look at my Ballast where do i need to start? Because if you look here http://forums.vwvortex.com/zerothread?id=2632686 I cant correlate its relation to mine.
1 other thing too, when i went to screw the bulb into the socket, it doesn't want to fit in there and it wont turn into place. they are the 9006 bulb though. Should i just muscle it in there?
Thanks acleansc4 and what kelvin are your HIDs?
Also, dont try and muscle anything, just check if anything is blocking it, and try over and over again, sometimes its tough to get the little hedges lined up. Easy does it. ( i had the same issue last night when i replaced my fogs, took me a while, but out of nowhere, it poped right in just fine.)
I found a Relay Kit online. So i believe i am set with that. Still having issues with the bulb though. I will fiddle around with it some more tomorrow. Thanks for your input guys.
Johnathon
Johnathon
Congrats. I've played with these before and can offer some clarification. They're nice in the fact that when they ignite, they don't have that sudden flash like a majority of the HID kits on the market. In my experience, only Philips and these Bosch kits have that "feature". These specific Bosch kits are made in China to German specifications.
With regards to the bulb not fitting, make sure you're trying to replace the low beams and not the 9005 high beam bulbs.
Good luck!
c.
Good luck!
c.
That's what I did I think we're both smart
Yea i think it is pirated... But it has a code of authenticity... Is that how i go about getting the warrant or...?
And i will try and get a better cut off line for you guys... to me it seems like my left one is too low.
