(56k = fail) My First Retro :)
Old 01-15-08, 08:07 AM
lexus4jess
lexus4jess's Avatar
Looks good.I use a water jet to do my brackets.
https://www.clublexus.com/forums/sho...hreadid=126882
Old 01-15-08, 10:29 AM
ACleanSC4
ACleanSC4's Avatar
Originally Posted by BLK13X
Hey dudes,
While messing around with the headlights last night (a mate of mine is doing a retro on his Y32 Cedric) we were discussing if the auto-leveling function could be incorporated into the retro. Has anyone been successful in fitting one to an SC headlight? I'd be worried that the headlight would suffer from leakage if it wasn't sealed properly and that the motor/solenoid unit is too big for the headlight back housing.
What do you guys think?
I don't think there's enough room for autoleveling...but I'd love for someone to get it working!
Old 01-15-08, 10:06 PM
BLK13X
Mortgage Slave
BLK13X's Avatar
Yeah, the more I look at it the only way that I can see it fitting is if I...
  • Remove the top aiming adjuster and dapt the solenoid fitting from the RX330
  • Remove the paring light make the bracket to span the distance to the parker and replace the parker with a CCFL ring around the projector
Too much effort I think. And I don't think there's enough space for the projector to move up and down
Thanks mate, it was actually indypwr's retro on his old white SC300 that made me want to change my PnP kit to a full retro. Just curious, do your brackets fit only the Audi TT projectors or can the be made to fit any projector?
Old 01-16-08, 11:09 PM
BLK13X
Mortgage Slave
BLK13X's Avatar
I think I'm closing in on this whole bracket situation Only way I can see the bracket fitting the projector is if part of the top aim adjustment is slightly tapered in one corner to clear the projector itself... there shouldn't be too much problem doing that? Oh and one of the screws for the ball joints will have to be removed since it comes in waaaaaay too close to the projector mounting hole.
So it's off to get a prototype made up and if all is well then straight to the machine shop to get it cut
Old 01-21-08, 06:29 AM
RX469
RX469's Avatar
wow wow wow! Very nice.
Old 01-29-08, 11:13 AM
tiguy99
tiguy99's Avatar
Keep us posted! It looks great. Sorry if I missed it earlier but BLK, do you have any plans for the lenses?
Old 02-27-08, 05:25 PM
400DGRZ
400DGRZ's Avatar
any update?
Old 03-21-08, 01:49 AM
BLK13X
Mortgage Slave
BLK13X's Avatar
^ Hey,
I'm waiting for my brackets to arrive (thanks to Lexus4Jess). It's all paid for and sent but it's taking it's sweet **** time to get to Oz. Does anyone know how long first class mail takes to arrive?
When they arrive I'll be back on to the project, as without that I can't put my retrofit together
Old 05-28-08, 06:43 AM
KoSC300
KoSC300's Avatar
hey man.. you get your brackets yet? i would like to see this project finalized.
Old 05-29-08, 04:07 PM
Kyle Harty
Kyle Harty's Avatar
Nice work. Should look great!
I think you need sensors on all four wheels for the auto-leveling to work, doesn't seem practical to figure out how all that would work, although I'm sure it could be done if one was determined enough.
Old 05-31-08, 11:11 AM
sleeper408
sleeper408's Avatar
Nice work. I misread the title and thought you failed your first retro.
Old 06-01-08, 06:17 PM
1GStoEnvy
1GStoEnvy's Avatar
Location: ~SIMPLY TUCKED~ scraping the mean streets of L.A.
any updates yet...
Old 07-04-08, 12:05 AM
BLK13X
Mortgage Slave
BLK13X's Avatar
LOL sorry for not updating this thread
Anyway, the retro is only half done, I still have to deline the projector areas on the lenses, and I might sand back on the brackets however they're in and they work fine. I'm running D4S ballasts/bulbs. I've had the retro installed for about a month.
Sorry about the crappy picture quality.
The RX non-AFS projectors are huge... barely fits in the Soarer housings.
The cut off is blurry, I still need to deline the lenses... these next few were shot from about 15m (approx. 50ft) from the wall.
It's my first shot at a retro, but I would recommend doing a proper retrofit over a PnP kit anyday (or should that be night?) of the week.
Cheers
Jose
Old 07-04-08, 08:12 AM
Temptation
Temptation's Avatar
Wow, very nice cut off you have there -- great job !!
BTW, are you sure the light beam doesn't blind the oncoming vehicle? I'm not sure, but it seems a bit high?
Old 07-04-08, 12:17 PM
Jewcano
No Sir, I Don't Like It
Jewcano's Avatar
I agree, Even though you are RHD, the drivers side light does seem a tad high. Might wanna drop it a bit.
Quick Reply: (56k = fail) My First Retro :)
