Driving Lights on 2GS (full on???)
I have 2k GS3 and the driving lights (the ones always on) are very dim. Is there a way to make them turn on fully as they use normal headlights in that location but it's dim.
Thats just the DRL and DRL uses small wedge bulbs. There is a link on the main lighting page for different wedge bulb options that you can use. IMO there is no point putting a high wattage bulb in that spot since it will only cause glare. If you really want to have a different look than go for something thats a bit more white rather than the current yellow wedge bulbs. Options on the bulbs are listed in the thread I mentioned.
Funny... That's not the point... These are DRL's and are on when the Headlights are Off. I believe the Wedge Bulbs comes on when the headlights are one. For high beam operation, they should be one with the Headlights...
Does anyone know how many wedge bulbs are in each side? And will these work:
http://cgi.ebay.com/ebaymotors/PIAA-...-/200450788853
Thanks.
Eric
Thanks.
Eric
smooche
12-16-04 03:46 AM
