New Owner.....need help with AUTO Leveling...
![Unhappy](https://www.clublexus.com/forums/images/icons/icon9.gif)
So, I picked up a used 2001 Lexus GS430 this weekend. Great car, but I noticed in the mornings, when I start the car, the auto leveling headlights don't both work. I see the drivers side go down, up, and then level out. But the passengers side headlight shows no movement whatsoever.
So....what would be the first thing to check? I'm completely new to this, so any advise/insight would be appreciated.
Thanks,
- Zishan
Thanks,
- Zishan
you may have to manually adjust them with a screw driver.
it can be a real b*tch, so get some help from someone in your area who has done it before. this is assuming nothing major is broken.
if it has those headlights that turn with the steering wheel, then i cannot help you
Thanks! I will definitely check for those.
