Using Home oven
Old 02-19-08, 01:13 PM
keng714
keng714's Avatar
Default Using Home oven
will there be any problems using a home oven to pull apart a headlight? like chemicals burning off in the oven that could cause problems.
Old 02-19-08, 01:30 PM
emoshun
emoshun's Avatar
Nope, none!
Old 02-19-08, 02:07 PM
URDONE
URDONE's Avatar
Lol. I hope not.
Old 02-19-08, 03:08 PM
JnC
JnC's Avatar
I use a heat gun , best $15 I ever spent, have had it for about 3 years now and I have unglued/glued some 50 odd headlights with it .
Old 02-19-08, 03:13 PM
chrispy
Forum Moderator
chrispy's Avatar
I guess I'm unskilled with the heat gun, because it warps the housings when I do it. The oven heats all the glue evenly so I prefer it over the gun.
Old 02-19-08, 03:46 PM
mikal
mikal's Avatar
i find it pretty difficult with the heat gun. I used it on a set of headlights once (GS) and it took forever!!
I recently used the oven method on a different set of lights (SC) and it was fast and easy.
Oven trick is the way to do it.
Old 02-19-08, 03:49 PM
keng714
keng714's Avatar
okay thanks just didnt want to mess my oven
Old 02-19-08, 06:18 PM
mikal
mikal's Avatar
you wont mess it up. Just clean your oven after if you're afraid it might leave chemical residues
Old 02-19-08, 06:50 PM
lilboi
lilboi's Avatar
Make sure you do it on a baking pan when you do it. I always like to line it with foil that i can discard after use. The heat gun is a very good tool, however when opening a headlamp with such curvature and area, it's good to start with the oven and use the heat gun as a tool to keep the glue soft.
Old 02-25-08, 01:07 PM
elucid8
elucid8's Avatar
What do you guys use to protect your hands, when using the oven, to pry apart the headlight? Do you use a terry cloth to hold the housing and a flathead to pry it apart or something?
Old 02-28-08, 02:39 PM
ddb
ddb's Avatar
In most cases you should be able to use the oven in your kitchen to open your headlights without any problems.
To avoid any problems, make sure there is nothing else in the oven, including the grills (except of course the one you sit the headlights on). You can also sit the headlights on a metal tray if you think they could leak (this is a good option to have “peace of mind”).
Always ventilate the oven before and after. Before so your headlights don’t smell like roasted meat, and after so you evacuate any gases from the process (they could be kinda toxic in some weird cases).
Make sure not to overheat them. Usually 150 degrees is enough, but you can try different temperatures until the headlight is hot enough to open them.
To avoid using the kitchen gloves, try using gardening gloves when removing the headlights from the oven. Make sure to have a place ready to put the headlights as they will be hot!
Last, make sure to apply even pressure with anything you might use to pen the housing. Don’t open only one side. Keep on applying pressure evenly around until the housing comes apart.
Have fun.
Old 02-28-08, 02:57 PM
JesLet
JesLet's Avatar
295-300 degrees. 7-10 minutes. Don't worry it won't melt like a butter.
Old 02-28-08, 04:06 PM
ExTrEmE99
ExTrEmE99's Avatar
so what to do with re-sealing the headlights? would the factory glue be reusable or should you re-apply some glue?
Old 02-28-08, 09:51 PM
JesLet
JesLet's Avatar
Yes, you can use it just make sure there are no debris. I resealed it with some silicone from auto parts store just for the heck of it. I resealed the outside part only.
Old 02-29-08, 12:39 AM
pnyboy27
pnyboy27's Avatar
yea..plus the bottles of that stuff isnt that expensive either. i used some of the black silicone stuff to reseal mine
Quick Reply: Using Home oven
