fx35 retrofit into 97 Lexus ES300 headlight project...
Hey guys,i usually just post in the es300 section but wandered over here today.
Basically this week I will be getting all my parts mailed to me.I have 2 complete fx35 headlights coming.And I mean projectors,bulbs,ballasts,etc. Everything that is attached to the headlights basically including the harness.
So just wanted to make sure I got my facts right..
From my understanding the backside has a nice size gap hole BUT doesn't condense or anything.Because the size of the opening lets it vent the condensation out before it actually builds moisture??
Is that right?Thats pretty much all I need to know.
I was wondering since I saw this progress pic of one being done and noticed the huge square cutout.No way the projector would fill it in perfectly.
![](http://i28.tinypic.com/2u5wd4i.jpg)
![](http://i29.tinypic.com/33kvghz.jpg)
I'll update this when the parts come in.![Smilie](https://www.clublexus.com/forums/images/smilies/smile.gif)
I know tsx and s2000 projectors are better but im not striving for the ultimate best.I would just like better lighting than the stock halogen setup.
-Alex
-Alex
Not sure if you are a member at HIDp but here is a method I have devised to mount projectors onto a reflector. The ES headlight is almost identical to the one used in the following case, 00 TL. You can use the four bolt method as well its easier than the method below but make sure you do all your alignment before sealing everything.
Well time has come to make a dedicated thread about the rotational adjustment method that I have been using over the past year or so in my retros. I have been describing it to other members in their threads but i think its better if I have one thread where I explain everything for people who might be interested in using this method. There are two methods that I imply, one is for retros that you mount on your existing reflector and one is where you actually mount the projector/s to the headlight housing rather than the reflector.
This thread will explain how to mount on a reflector using brackets.
If done accordingly you will have fully adjustment capability that is horizontal, vertical and the dreaded rotational even after you are done sealing your headlights .
I'll be using pictures of an old retro I did back in may on a 2000 Acura TL. Space is very tight in this headlight you can barely squeeze a medium sized projector in there, such as the S2k, and have adjustment capabilities.
This set used a set of SC430 projectors with a set of E30 clear lenses.
The actual projector
http://maxupload.com/img/4D639B13.jpg
Both projectors shaved down to bare essentials.
http://maxupload.com/img/D0D059CB.jpg
I usually take the lenses off before doing the work and install them once the retro is ready, this way you avoid the chance of damaging them
http://maxupload.com/img/3ADD1608.jpg
The headlights
http://maxupload.com/img/E5A78544.jpg
Acura TL uses reflector based HID set up, i draw rough reference lines to know where the bulb sits, perpendicular axis for cut off reference.
http://maxupload.com/img/6F9A2C83.jpg
Now this is very important. Every headlight has guidelines somewhere along the reflector that indicate perfect line out of the headlight i.e. a line that runs parallel to the OEM bulb. This will be used to allow us to figure out where to drill holes to mount the projector. Using this you can get a perfect beam on the horizontal axis and can be further tweaked using factory horizontal adjustment screw. The line starts from right underneath where the OEM bulb sits and is parallel to it.
http://maxupload.com/img/4C02C7F2.jpg
There are two lines in the above picture only one is the correct one, when you do yours you will only draw one after calculating the exact location and direction.
After etching that line and using a ruler draw a perpendicular line to this line. On the perpendicular line you will drill two holes that you will use to mount the projector.
Notice the perpendicular line and notice the etches in the reflector, all those etches are parallel to the bulb.
http://maxupload.com/img/FE495C7F.jpg
After using dremel to make hole in the reflector this is how the projector looks sitting inside the headlight.
http://maxupload.com/img/00B8634E.jpg
The Brackets
Brackets are made out of 1/8'' thick stainless steel, you can pick up a piece at your local body shop or even home depot. As you can see you dont need much of it. They are bent at 90 degrees and are drilled and tapped for 10-24 size screws. Also notice the two mounting holes in the projectors on the bottom, i'll come back to explaining their location in a bit.
http://maxupload.com/img/A8220162.jpg
http://maxupload.com/img/25B16EE3.jpg
Notice that i have cut corners towards the top of the bracket, this will let the projector rotate without letting the bracket hinder anything by touching with the projector. Every projector is different, the SC and S2k dont give you many options and metal to work with as far as drilling holes go.
http://maxupload.com/img/146E44B4.jpg
http://maxupload.com/img/4656F17D.jpg
In this method you will use three mounting points. Two holes for the brackets at the bottom and one at the top which will control the pitch of the projector.
http://maxupload.com/img/ABCF529E.jpg
The mounting screws
As stated earlier these will be placed on the perpendicular line drawn earlier. Each is as far apart from the center line as the holes in the projectors are .
http://maxupload.com/img/36857F7D.jpg
http://maxupload.com/img/10273ED3.jpg
Dont mind the epoxy on the side, it was to mend a crack in the reflector.
http://maxupload.com/img/B506A37A.jpg
The hole in the projector is a hair bigger than the actual screw. This is done so that the screw doesnt bind with the projector, holds the projector in place yet lets it move freely. Screws would go through the hole in the back and then into the tapped holes in the brackets. They are not tightened fully, a slight play is left and after the final install a dab of lock tight is put on them so they dont come loose later.
http://maxupload.com/img/7B00AB56.jpg
This picture shows what the final mount will look like, notice that i used regular washers for mock up, at the end you will use sealing washers. These are washers that have rubber on one side and aluminum on the other. The rubber side will be against the reflector to ease the pressure on the projector, which is more than what people exert on it using the regular mounting method, also notice that the projector is sitting on the reflector rather than haning onto it.
http://maxupload.com/img/50038EA0.jpg
Pitch adjustment screw on the top.
http://maxupload.com/img/D63283D6.jpg
http://maxupload.com/img/75123A83.jpg
This is how the projector would look when mounted.
http://maxupload.com/img/4E2E8BA7.jpg
http://maxupload.com/img/47543ACF.jpg
http://maxupload.com/img/F4EE6AB4.jpg
http://maxupload.com/img/4C2A0622.jpg
http://maxupload.com/img/5515C015.jpg
This is the final mount, the excessive brackets sticking out are cut, lenses mounted.
http://maxupload.com/img/B817C9BF.jpg
Notice the sealing washers used.
http://maxupload.com/img/FA3C964A.jpg
http://maxupload.com/img/06FE0A59.jpg
http://maxupload.com/img/B21F27E5.jpg
http://maxupload.com/img/A91F60DC.jpg
Do some initial testing by mounting the headlights on the car.
http://maxupload.com/img/4A7CA352.jpg
Each mounting screw on the bottom when rotated pushes the projector up and down from its side, this way you control the alignment of cut off . Clockwise to lower it and vise versa.
Initial fire up.
http://maxupload.com/img/867E5DD7.jpg
Some tinkering with the adjustment screws and this is what you get
http://maxupload.com/img/F553C9BD.jpg
After the headlights are sealed you might need a tad bit of adjustment for a perfect beam for this purpose you drill a small hole on the bottom of the headlight to gain access to one of the mounting screws, pick whichever one you can have easier access to after the install.
This is how the output looked after the sealed headlights were installed .
http://maxupload.com/img/B96C712A.jpg
http://maxupload.com/img/56ECA942.jpg
http://maxupload.com/img/5CCC57D0.jpg
http://maxupload.com/img/1C51A2E8.jpg
http://maxupload.com/img/B7905356.jpg
This concludes today's session ladies and gents . I hope this thread helps, i am sure it will since a few members have already used it. I see some people have used springs as well, although i love the idea but the springs may wear out after a while hence I suggest the drill and tap method for the brackets. You can pick up a drill / tap set for 10-24 screws at home depot for 3.99 .
If mods think that this thread will help the masses then feel free to move it to the university section .
The headlights
The Brackets
The mounting screws
Initial fire up.
Ok here are a couple of pictures (dont mind the camera phone quality), these are shaved to the bear minimum. You would need to put some aluminum tape on the top to cover the hole on the top.
![](http://img175.imageshack.us/img175/7915/photo031708001hk9.jpg)
![](http://img339.imageshack.us/img339/1299/photo031708002lf3.jpg)
![](http://img172.imageshack.us/img172/408/photo031708003sh5.jpg)
and here is a picture from ebay to show what the FX projector looks like stock without any cutting.
![](https://img411.imageshack.us/img411/7230/ebaypics396ja2.jpg)
Alright here goes what I got so far..
the headlight..
![](http://i29.tinypic.com/iqa43t.jpg)
OEM bulbs and ballasts...
![](http://i28.tinypic.com/12176zl.jpg)
Upclose of opened headlight.I like the smoky color
![](http://i25.tinypic.com/sdjsxd.jpg)
![](http://i29.tinypic.com/fmuald.jpg)
The fun part,the projector...
![](http://i31.tinypic.com/9zvyw3.jpg)
the headlight..
![](http://i28.tinypic.com/15v91f.jpg)
It looks like a clear lensed FX, FX have 4 or 5 different variations of lenses, from crystal clear to heavy frost. Take pictures of the glass lens on the projectors and post them, lets see if they are indeed clear. The shield in the middle (between the bowl and the front part of the projector) is golden which indicates the clear lensed version where as frosted ones come with a silver shield.
Ok so I got my friend to help me do the install.Everything seemed fine.I opted to use "QuickSteel" puddy to hold the projector,instead oh having exposed screws.Only thing is my friend failed to realize one thing.Well its perfectly centered and all.He pushed the projector all the way back....but it was facing a little down
Which once installed its pointing WAYY too low.So in the end not even the adjustment screw can fix it.Belive me its lighting up the ants on the ground but thats all.lol
So tomorrow gonna have to try to get that puddy off somehow.Oh yeah since we didnt have something to shave the fx35 projector nicely,we ended up using the other projectors.I kinda like it without a shroud since it has like an X design..
![](http://i27.tinypic.com/dqgdtt.jpg)
If someone wants the BiXenon fx35 projectors lemme know.Ima sell them soon.Right now I rather buy another set of headlights and start all over.
Anyone got some spares? lol.Im sure these are salvageable but I wanna be minty fresh.
