LS430 projectors
Aloha everyone...
I just acquired another set of HID headlights for my 2GS, so to get my retro project started, I need some LS430 projectors.
My question is where is the best place to get a set of LS430 Projectors besides ebay? Also what are some comparable projectors with the same output as the 430's & where to get them? Any help would be appreciated.
I had a feeling I was going to hear that bout the 430's being the best... I'm not that much a fan of the TL's & S2k's. Does HIDplanet normally have them readily available?
Mostly because its a more common swap, but seeing them next to a 430's output was a bit striking. They're good dont get me wrong... S2k's cut off is lovely, but well, I think I'm set with the 430's.
yep, i think S2K would be the second choice if you can't go with LS430. i have LS430 and when i was driving on the freeway last night, i saw an S2K had pretty nice cutoff and very wide beam too. but yeah, nothing can compare to 430. they are godlike. they light up the whole 5 lanes freeway. holyyyy!!!!
Well looks like I'm going to hold out until I find some LS430's I suppose. I just missed a set by about a month...
I haven't heard about M45's but, I'm less concerned about the shroud look than the out put. I'll have my eyes open for a set of 430's.
just curious... i have an extra headlamp from my 2007 ES350... i sorta broke the housing... the part where the bulb fits in.... i was thinking of playing around with the headlamp and doing a wicked retrofit... dual bi-xenon projectors for high and low beams. wire it so they both run on low beam.... and open up on high beam.....
1 is it even possible?
2 what type of projectors should i stuff in it?
3 if not possible... just retrofitting the low beam... will the ls430 projectors fit?
4 what do i need to do this job flawlessly... (never done this before)
5 most importantly... how much will a job like this run me? material wise..
