DIY: Fix for fogging 2GS headlights :)
#32
I washed my GS and the driver side headlight is absolutely ridiculous with how much moisture is in it from all the rain. The entire plastic area is covered in thick dull yellowish colored moisture drops that makes the headlight and inner light looks terrible. The driver said is not too bad and pretty clear with only a small amount of moisture which I don't mind. Unfortunately there is a bunch of metal bracing covering those screws to get at the levels. Maybe Home Depot or Lowes has a special screw driver that can get at them because there is no way I am going through the headache of taking out all that bracing just to get at those screws. There is so much moisture it is hard to believe it is coming just from that one area.
#33
#34
I know this is for GS, but like i installed HID's in my Gf is250 and recently iono if its cause its been raining like crazy or the car cover she started using, the headlights has hella moisture, does the IS250 have a vent for moisture to leave? im thinking of going back to stock bulbs and replace the low beam cover since i had to drill it for the hid wiring...you guys think it'll be covered under warranty it was 09' with like 4xxx miles...im hella stressed out since...i installed it =(
gonna try to blow hot air in it to see if it helps, or could turning on the hi beams help dry it out?
Thanks
Thanks
#35
Would the SC300 have the same fix for this issue?
New pictures
Remove the cover, yours might look a bit different as some headlights had bigger covers.
Put RTV silicone in the channel, as shown.
Put the cover back on, DO NOT PRESS IT.
tighten the screws gradually, you may see some silicone ooze out of the sides.
Note: this will only make sure that water doesnt get inside the headlight from this particular opening. It wont rid the moisture already present inside the headlight. You may want to throw in a pack or two of 5~10 gram weight silica gel desiccants.
#36
There is metal bracing over those levels and most screws to get the cover off on my GS430, I guess you have to take all these metal pieces off just to take all the screws off and open the plastic top to try to reseal the plastic cover. I was hoping you could just get at the screws but with the metal blocking a couple it is going to be much more of a pain to take all those metal pieces off. Anybody have any issues when taking the metal bracing over the levels off?
I drilled a small hole in the bracket above the obscured screw, just large enough to fit a small Phillips screwdriver through. The metal thickness here is very thin...I used a punch to center the drill bit and keep it from walking. Drilled thru rather nicely, and the screw is very easy to access with the new hole.
My $0.02.
#37
Reference Post #18, Photo #2. I have a 99 GS400.
My $0.02.
My $0.02.
