yellow or clear?
I like the clear if you're putting HID's in them, otherwise I'd stick with the yellow. I was on the fence about this for a while, I just switched to 6000k in the stock HID's and the same in clear fogs and I love it; but there's something to be said for the yellow "Lexus look" too.
If you put a 6000k HID into headlights which is light white blue color. Will it be defecting the purpose for putting the Yellow fog light down? (light white blue +Yellow= Light Yellow?) Has anybody compared the output for 6000k with 3500k and 6000k and 6000k with clear fog to see which is BRIGHTER or CLEARER?
Yellow foglights are nice for conspicuity, especially in adverse weather conditions. Probably don't help an awful lot over white to actually see throught the fog (although there is the argument that the yellow light enhances contrast), but they sure are more visible to other drivers.
_________________
Check out: Volkswagen Blog
_________________
Just got my yellow 3000k HID installed in my fog light. Ask per Och. Looks much more brighter. Poor light bulbs, enclosed into a tight yellow capsule. I am worry about the heat, pretty hot even without the yellow capsule. There is no place to put the HID ballast on driver side, I have to ziplock to 9006(high beam) wires.(where do you put yours Och?)
Funny thing the fog light started as green, then transited into yellow in 10 seconds.
(Cheap Philips 6000k light bulbs, like 5000k and less blue/bright then my other aftermarket 6000k car .)
Sure yellow make your car stand out and Lexus look. I kept mine on whenever my low beam on now.
toy4life86
09-25-13 10:19 PM
Chumacher
06-12-08 10:55 AM
