If you were referring to me try clearing cookies and trying again. It worked when I clicked and added stuff
I tried, I've never had this issue before. I deleted all my cookies and everything. I tried IE and Firefox on my laptop and desktop. Why won't this work.
hm.. i have similar problems with my yellow HID fogs... can this also solve my problem? i have a cheap Ebay kit.... thing is... both fogs are off sometime.. turn the fogs off and on.. and they stay on... sometimes when you start the car.. both turn on... or just one.... kind of a mystery to me...
Sounds like you have a voltage suppply issue. If BOTH are doing the same thing off and on, it is a power thing. The solution would be either a relay or a set of capasitor harnesses. That should help steady your input voltage and stop that from happening.
It's not the bulbs.. it's either the ballast or ignitors.. lots of aftermarket kits have this symptom of one not coming on then when you turn it off for a while and turn it back on they both fire up again. My xenondepot kit is like this so is my DMM kit for my volvo. Although it happens much less on the one on my Volvo it still happens occasionally.
for me it was the bulbs. because i switched just the bulbs and the same bulb didn't turn on. so...yeah...
I already have one and I still got the one bulb out all the time. The other guy talked about a capacitor harness though which should be different. I might give that a try.
Originally Posted by GCOP
Thats a relay harness a capacitor harness has a capacitor on the positive side of each of the leads to the ballasts.
