fog light question
Old 11-12-02, 05:41 AM
girvan
girvan's Avatar
Default Dangerous Suggestion
I successfully modded my 98 GS400 to do something similar with fogs lights on high and low beam and posted it here a few weeks ago. That used a single diode between two connections on the light switch.
To keep the fog lights on with the parking lights (and high and low beam) try this variation:
• On the light switch connect the –ve end of a diode (1amp / 50V or similar) between pin 11 (or 18, as they are looped) and the +ve end to pin 15
(18 grounds with low beam only, 15 grounds with parking lights, 11 is fog control (via light ECU)
BEWARE I haven’t tried it so be careful. Can someone with experience of car electrics verify that this works? I wouldn’t normally post something I haven’t tried but this seems a lot easier. I do not know how much in common other years and models have for light switches but assume that it is a lot.[B]
Uzairlexus
Hybrid Technology
09-22-20 02:51 PM
Chris442
12-31-15 05:00 PM
YupImJOee
GS - 1st Gen (1993-1997)
26
09-28-10 07:29 PM
Adam2562
03-20-06 11:42 AM
gp1200x
RX - 1st Gen (1999-2003)
03-11-04 09:22 PM
Quick Reply: fog light question
