Red lighting
iModerate
RED HID - Never seen it. I doubt it is available.
RED H3 - Have not seen this either.
You will most likely have to use a red lenses to achieve the look you are going for. You can also try Red "Angel Eye's" in your head lamps. Another option is Red LED bulbs.
As stated above check you local laws if you are planning on using this setup on the street. Stick to Show / Off Highway use.
kadify
02-28-14 02:12 PM
