Led/Hid retrofit review from V-LEDS.com in my 00 GS300 (lots of pictures)
Old 12-19-12, 07:28 AM
  #181
sakataj
sakataj's Avatar
Originally Posted by celm
I put a set of 7440/7443 white led in my back directionals, now when i turn the directional right or left. it flashes very fast like there is a bulb out,but when i checked there isnt. When i put the hazards on,the flash is the slow normal speed.Any insight on this guys and my car is a 99 aristo
u need these.....
http://www.v-leds.com/Load-Resistors...-p8726800.html
i just bought some the other day from Bill @ V-led to do rear ones.... havent had time to install them yet though.
BTW if your JUST doing rear LED's then you need the 6 OHM resistors but if your doing front/rear turn signal LED's you need to use 3 OHM resistors (and need 2 pair instead of one pair you need)
i also bought these as the Junction produce tails i bought are clear, i didnt want any amber showing through them, so im gonna try these
http://www.v-leds.com/AMBER-7443-21-...-p9812608.html
if i dont like them, im gonna convert to a dual 7443 bulb and get a switchback like this
http://www.v-leds.com/6K-TYPE-2-DUAL...89718-1-2.html
but im 99% sure the first bulb i linked is gonna work well for me
WARNINGS about load resistors
they get REALLY hot and you do not wanna have them touch any plastics as they will melt them, thats why i went with these ones mounted to a metal plate to help dissipate cooling compared to these
http://www.v-leds.com/Load-Resistors...-p4783296.html
NOW had i noticed they had these,i would have gone with these as these should also help in cooling and keeping the load resistor off parts it shouldnt be on
http://www.v-leds.com/Load-Resistors...-p8795272.html
actually im gonna go buy those so if you wanna buy my BNIB one's let me know
they are a easy install though as they arent directional and either side can be tapped
Old 12-31-12, 08:29 PM
  #182
celm
celm's Avatar
i got a question about the resistor box, they give the warning that they get very hot. now do they start warming up when the car is turned on or when that light its correcting is turned on? example if i need it for my blinkers,will it only start getting warm when i turn my signals on and leave them on? if i turn my signal on to make a turn and so its pretty much only flashing for a few seconds and will start to warm up during thats few sec?
Old 01-02-13, 04:22 PM
  #183
celm
celm's Avatar
can anyone answer this?
Old 01-02-13, 10:43 PM
  #184
sakataj
sakataj's Avatar
only when the blinker is on....
Old 01-14-13, 09:17 PM
  #185
FinLIFE
FinLIFE's Avatar
Im curious as to why they list the front turn signal bulb to be 1156 when I know for sure its not that bulb on my car.
I figured out that both front and back we use 7440/7443. My question is..v-leds offers both standard and ck style bulbs. Anyone know which we need? I could go out and test them myself, but its so frigging cold here that I dont want to right now.
Old 01-15-13, 12:27 AM
  #186
sakataj
sakataj's Avatar
could possibly just be a error, email bill from Vled. btw we dont use a 7443.....we use a 7440. 7443 is dual filament and we use the single filament 7440 bulb.
Old 01-20-13, 09:55 AM
  #187
FinLIFE
FinLIFE's Avatar
Brian, do you know if we have standard or ck type bulbs for turn signals? V-leds has 20% off and I might place an order for some bulbs before its over.
Also, do you know if its possible to switch out our flasher instead of using the resistors?
Old 01-20-13, 08:06 PM
  #188
sakataj
sakataj's Avatar
the electronic flasher relay doesnt work on our car for some reason.....or it didnt for the few people who have tried it.
what do u mean standard or ck type bulbs?
Old 01-25-13, 08:08 AM
  #189
LexusK
LexusK's Avatar
VLEDs has a new coupon code 10k35 for 35% off your purchase. If any of you 2GS guys are replacing bulbs, post up which ones you're getting! I don't trust myself enough to order on my own lol. I just want super white lightsss!!!
Old 01-27-13, 11:24 PM
  #190
sam430
sam430's Avatar
New LED technology around the corner.
http://www.pressreleasecentre.com/liquidleds-launches-new-line-of-uraden-led-lights-44634/
3U and 2U LED light, generate 9530 and 1350 lumens of light respectively.
Old 02-01-13, 07:38 AM
  #191
Dranom
Dranom's Avatar
Good review!
Old 02-01-13, 08:49 AM
  #192
LuiB
LuiB's Avatar
That looks awesome. Have you considered any shield mods for your new projectors?
Old 03-01-13, 03:13 PM
  #193
LexusK
LexusK's Avatar
Got these for my footwells, but they are a little too wide. Are there any bulbs that are a direct pnp? Jackson modified his bulbs, but I dont want to trim the housing or solder wires. What did you guys get?
http://www.vleds.com/5k-white-3-led-...74-1-pair.html
Old 03-19-13, 12:16 PM
  #194
sakataj
sakataj's Avatar
i have been using Vled 's 74's for awhile with no issues, actually just replaced one today i ordered a few weeks ago and it fits fine..... so not sure why you think they are two wide
BTW jackson modified this bulb to get more light NOT because the 74 wouldnt work there
Old 03-20-13, 06:13 PM
  #195
sleez3
sleez3's Avatar
i just did this today myself. mine also didnt fit well, seems as though the 3 smd is a tad thicker than the 1 smd. @sakataj did you buy the 3 smd? i tried the 1 smd that i bought for my keyring light and it fit well. idk...i may just cut the connector and put a small board in there
Quick Reply: Led/Hid retrofit review from V-LEDS.com in my 00 GS300 (lots of pictures)
