Led/Hid retrofit review from V-LEDS.com in my 00 GS300 (lots of pictures)
#196
Got these for my footwells, but they are a little too wide. Are there any bulbs that are a direct pnp? Jackson modified his bulbs, but I dont want to trim the housing or solder wires. What did you guys get?
http://www.vleds.com/5k-white-3-led-...74-1-pair.html
i just did this today myself. mine also didnt fit well, seems as though the 3 smd is a tad thicker than the 1 smd. @sakataj did you buy the 3 smd? i tried the 1 smd that i bought for my keyring light and it fit well. idk...i may just cut the connector and put a small board in there
im gonna reorder some of these
http://www.vleds.com/bulb/74-led/whi...74-1-pair.html
and if they dont work out to my liking i will go to a board also probably something like this
http://www.vleds.com/universal/circu...5-1156-57.html
although i wish they had a PNP base like the others do for the 74
http://www.vleds.com/universal/circu...pters-5pk.html
#197
yep, those are the same ones, no good for the footwells. the 1 smd will fit, but the output will be **** poor at best. i agree, if he had a universal #74 base we would be made in the shade. I swapped out everything on the dash and interior lights to vleds. he does have a lot on back order, not sure how long the wait is. keep us posted on your progress.
#198
#199
so thanks to LexusK i have measurements on the 5 SMD ones and i measured the single SMD ones
the 5 SMD is 19.5 mm tall, 4.5mm wide, 2mm thick and the single SMD is 19mm tall, 4.76mm wide and 1.58mm thick maybe its the thickness of the 5 smd that is stopping it from fitting it in our 74 slot. i emailed Bill and will see what he says
#201
Hey, thanks for the leg work... I think I may just cut the socket and put a small board in there. The one SMD just doesn't get it done, for me. I will just order the board, it's to much hassle to do a return. I will update the thread when I complete this. Right now I'm trying to research why my rear lights above the doors won't work.
KI_GSE21
RX - 3rd Gen (2010-2015)
09-03-11 04:17 PM
