How can i enable DRL in UCF20
My High beam's bulb are working XD
The day time light is disable.
***I searched.
PD do you know what else do i have to check ....wires, fuse or something?
***I searched.
qewani1, is there a label on the fuse box lid in the engine compartment like this one? The label on my 2000 LS400 shows one fuse and one relay for DRL.
I was under the impression that it took more than pulling this fuse and relay to disable DRL.
I checked the DRL fuse and its not blown , its ok.
This is a photo of mine engine room junction box, its same like yours.
http://i43.tinypic.com/2aiezap.jpg
i have just checked this Relay, relay's pins are ok.
any way PD & Kansas i had attached a PDF file from the repair manual part of "Body Electrical" which shows 3 more DRL relay one which is main drl relay is placed in passenger' s side & other 2 relays placed in downside of the driver side headlight.
"File is attached"
"File is attached"
The DRL relay which comes downside the headlight seems ok...btw i didn't checked them with Volt meter yet, because i don't have one LOL! no other way to test these relays?
The main DRL relay is aboard something like
![](https://tbn3.google.com/images?q=tbn:LutPtq8eLH3jPM:http://openeeg.sourceforge.net/doc/modeeg/images/analog_board.jpg)
maybe i must reprogram the main DRL board. how?
