LED in DRL housing longevity
I was thinking about picking up a 11SMT 194 LED, but I heard there's a high failure rate due to the heat. Anyone experience these problems. Does a halogen DRL running at low wattage heat up the LED enough to induce premature failure? Or should I just go pick up an M4 peanut bulb?
My advice would be to try a cheap-o pair of LED 194 bulbs first to see how long they last (you can easily find a pair for under $2.00 on EBAY.) Your experience may be different, but at least you can find out before dropping $13 on a really nice pair.
good luck
I guess I'll go with the 11smts from vleds then. Would go would want to go with the higher SMT ones but since it's a more complex structure, I fear it is more likely to fail or have pieces break off into the housing. Is 11smts still brighter than the incandescent alternative? It should match okay with mobilehid's 6k HIDs right (has a slightly purplish white hue)?
