Plug and Play
Plug and Play
can anyone list some options/sites for HID's that are plug and play for a 99 GS300?! And is there any particular kit that majority coniders to be the best, or most ppl use on here?
Thanks in advance, i just wanna see what options i have...
color is no issue i like the stock look, which i think is 6000k but i wanna get a set for my fogs too which i will prob get 3000k just wanna find a good brand thats plug and play and not too expensive....
yea i like the ones u pm'd me, but then i seen the xenondepot ones and figure i might as well see what other options there are...i just wanna make sure its a plug and play kit so i dont have to do any wiring.
This is the kit I use in my fogs. http://www.ijdmtoy.com/webpage/products/xenon.htm Have them for about 2 months and no problem at. All plug and play straight to your factory harness and no need to worry about having a relay to the battery and all that stuff. I've heard good reviews on VLEDs, too. http://www.v-leds.com/Shop/Control/P...d/0/SFV/32481#
Maybe have the ijdmtoy for lows and vled 3000k for fogs? Both use the digital slim ballasts. Or if you want you can also use XD volt kits http://www.kbcarstuff.com/HID_Kits_s/216.htm
No prob, volt is just the brand name that XD uses. But all three links I gave you all uses digital ballasts. Magnetic ballasts weigh more than do digital ones and they also run hotter than digital units. Because of the more consistent application of electrical current, the lamps last longer and function at a higher level using less power with a digital ballast than they might with a magnetic ballast.
