How to replace HID bulb? 6000k anybody?
The opposite side of the metal wire... push in the wire than move them to the side.. they should now be loose with one end attach...
As far as the place to get... I got my from http://www.suvlights.com/ for $275.. worth every penny that I pay for..
Originally posted by Shinchan
I have my Phillip 6K for over a month now... not bother by police at all! Phillip 6K is definitely look better than MB or BMW... but just a bit more blue than AUDI.. You won't be bother by police at all.. Just don't turn the light on when they are infront of you. The first minute worm up is very very blue.
Now 8K... Definitely look Illegal... way too blue attract more Police than you can say.. Sxxt not again..
8K is NOT illegal! heh.. definatly not
i think my low beam going be brighter then high beam
Thank You for help. Ordering my bulbs tomorrow. I don't want to break my HIDs so asking for more. As far as I understood I should push the metal housing in and than move it to the side.
Which direction do I slide it to? Another one what do those two metal wire peaces secure?Bulb? Please see my pic. I'm sorry about so many questions , just trying to be carefull with what I do. I'm planning to create a "How to with pics" for change HID bulbs. Is anybody intrested in seeing it?
Do not push the metal housing in. If I remember correctly, you twist it off. As far as removing the acutal bulb, push in the meta wire in and when press.. push them outward.l
Please Confirm:
Steps:
1. Remove the plastic cover by twisting
2. Make loose two metal piaces
3. Twist/TURN the metal housing
Twist clockwise or other?
4. Take the metal housing off with the bulb attached out of the lamp housing
5. Is that correct?
6. As far as removing the acutal bulb, push in the meta wire in and when press.. push them outward.l
Please explain more, I m confused . The metal wire is attached to metal housing wich I just removed by twisiting as in step #3
What do I see when I remove the metal housing?Bulb?
Thank You very much for your support
Please Confirm:
Steps:
5. Is that correct?
GS300.Ru: I will take some digital pic.. If its possible.. Its not easily to take that pic due to the spacing in the engine bay..
I know your pain and concern.. I got no anwer at all when I post the question myself.. about 3 month ago.. twice .. no one seem to know how to answer the replacement of the HID bulb...
I might not reply on this thread.. I think I will make a new thread..on this topic.. with digital pic.. just check the form again tonigh.. I think.. either tonigh or tomorrow....
Stay Tuned.. hang tight..
Originally posted by rominl
try the wire without the bulbs first, it's easier to get the feeling
what happens, though, if i put it all back WITHOUT the wires?
what function do the wires serve?
i managed to get it all back in and functioning (light, leveling)
without the wires.
Originally posted by jcondejr
good idea.
without the wires.
good idea.
without the wires.
just to check though, you put the bulb back, put the clip on, then put the power connector on, right?
hmmmmmmm, i've got it all put together, without the clip, though.
the bulb screws in and "locks" into place in the socket without
the clip. based on what you've just stated, the clip provides added
security. guess i'll take another look at it tonight.
