I can build you a relay with pre-made wires with "quick attach" wire taps. This will enable you to use all at once, all it takes is you to read which color goes on which wire and you will be set. email me jamodeo@gmail.com if you want me to build this for you... -Joe
With parts and fab, plus a write up, like 40-45 bucks plus shipping. I forget exactly how much the relays cost, so I will provide you with a receipt also. Let me know what you think. -Joe
BTW the install should be pretty easy, about a 30 minutes
Yea, I must throw in the disclaimer that you should only use this function if you off roading or it is legal in your area. Under no circumstances should you break the law by using this.
