about to buy HID from DDM
#42
still waiting on mine! oh and guys can i get the is a 194 (t15 white) at like a local part store? or do i need to order them? i kinda want blue. also on my head lights all that comes on is the low beams and side markers. no day time running lights and stuff like that. i got a 93 sc3 so no fogs either... just the turning lights.
#43
Then u connect the fuse holder to battery and to the relay.
The relay has a ground pin which you ground to the neg battery.
Then you quick splice a cable to the pos parking light cable and run that to the relay.
Then you gotta 1 wire from each fog light to the ground of the battery. (2 wires total)
Then finally you gotta connect both fogs to the relay. So you run a cable from each fog and then combine the cables together and connect them to the relay.
Also they make sockets that connect to the relay, so you dont have to solder the wiring onto the relay. I just used some female spade connectors. And if you dont know how to solder you can just use Crimp Butt Splice to connect wires together. Also make sure to use heat shrink tubing over either solder or crimpers.
Hope that helps.
#45
Can you guys tell help me with a few q's ?
Wil the 55 w one be safe in the SC, no melting ? Are they to bright, like do they blind oncomming traffic ?
Which xxxx K color is the whitest or closest to the Lexus new car factory ones. The new Lexus car one are suppose to image the sun.
