about to buy HID from DDM
so guys im about to order from DDM in the next few min here. im gonna order the 9006 55w 6000k DDM kit
my question is do i need to order anything else? or is that all i need to install them? i just wanna be able to get them in the mail and slap them *****es on
nope. should be all you need.
Just be careful with bulb life- their bulbs are most likely overdriven 35 W instead of true 50 watt HID like the Phillips DL50s
and overdriven 35 W bulbs will have lower life. and watch heat generation- some people have reported fading of chrome on shrouds from 55W HIDs
I order the DDMTuning kit 55w 6000k as well i havnt put them in yet but i have tested them and they look amazing. I plug it in to see if it would work and I left the plastic cap on
What do you mean by fading chrome on shrouds?
and it generated so much heat that the plastic was squishy but it didnt touch the bulb. Im going to install them tomorrow morning i'll post pictures where i set up the ballast.
However, the general consensus around HIDplanet is to use genuine phillips bulbs with the 55w ballast to reduce problems
its all plug in play. You might have to put in a higher fuse in the headlight fuse box depending on your amp draw. I have the 35W DDM kit in my sc with no problems. One of my friends had 55W headlights and fogs with no problems at all.
There are a couple diffrent ways. I have mine on the fender support next to the airbox just behind the headlight. For some reason my double sided tape keeps comming off so I think I might have to figure something else out. But I used the tape that came in the kit. I might end up using the 3M tape, gods fix all, other than duck tape. LOL!!! Good Luck
![](http://i216.photobucket.com/albums/cc243/joshuahenderson3/Picture006.jpg)
I order them on the 17th of december and it came in last week. And they just came in a box no instructions but its pretty much straight forward.. Heres where i mounted the ballast..
Driver side
![](http://i32.photobucket.com/albums/d43/whoaitzalex/P1110282.jpg)
Passenger
![](http://i32.photobucket.com/albums/d43/whoaitzalex/P1110283.jpg)
Right on the airbox im not sure its a good place to mount it but we'll see.
Driver side
Passenger
