55w ballast in OEM HID
Ive been having problems with my OEM HIDs on my IS350 and after thinking about it for a while, im thinking about going a different route.
https://www.clublexus.com/forums/lig...-bad-luck.html
(link to the problems i was having)
I was first thinking about just putting back the OEM bulbs on my car and having the dealership possibly replacing the ballast through warranty. But since i have painted my headlights (example shown below) i was thinking that maybe i should just buy a set of aftermarket ballasts (55w) and bulbs (6000k 55w) so that it would be brighter.
![](http://img241.imageshack.us/img241/7285/is5vw4.jpg)
(pic of scawacs' car)
What do you guys think?
Also are there any pros and cons to me doing this other than me voiding my warranty?
Would the auto leveling system still work if i swap out the OEM ballast?
Would converting to 55w from 35w damage any parts?
Hacked CL to become a Mod
hmmm I don't remember...but putting a higher wattage bulb (55w) in a housing that is designed for 35w will likely damage the bowl. The heat is likely to burn the reflector bowl rendering the projector unit useless....at least that's how I remember it. Go to HIDPlanet, they have something about this
I wouldn't.....50w ballast will generate too much heat. You will also be blinding the #$^#& out of everyone on the road. They put out a tremendous amount of light. I wouldn't have smoked your lens in the first place.
I have read on the boards here that some people were actually retrofitting their OEM ballasts to 75w.
But anyways, ive also read on HIDplanet that alot of people were buying 55w ballasts and using the OEM 35w Phillips bulbs and they were doing fine.. Alot of people were say that as long as you dont use the bulbs that come with the kit, its ok...
No because D4S is lower lumen output than typical mercury filled bulbs.
So you're starting off at a disadvantage from the get go, why boost D4S, when you can just switch to OEM D2S, be brighter, and then if it's not enough, boost the OEM D2S ballast and throw in the correct bulbs.
35W vs 55W HID Kits
55W HID kits do produce slightly more light (approximately 15%-20%) than a 35W HID Kit. This increased light output usually results in a less even light spread and additional glare. 55W ballasts are not as efficient as 35W ballasts that we sell meaning that 55W ballast longevity will be compromised. Many merchants that sell 55W HID claim that 55W is a superior technology. However, there is a reason that all cars that come with HID lights from the factory still use 35W technology and not 55W technology.
What is HID Technology?
Xenon HID lamps do not have a filament like a halogen bulb. Instead the light is created by an electrical discharge between two electrodes in an air tight tiny quartz capsule filled with xenon gas, mercury, and metal halide salts. This improves bulb durability as road vibrations can cause damage to coil lighting technologies. HID technology produces a blue-white light that is safer given that it is close to natural daylight. The color temperature is approximately 4200K compared to 3200K for halogen. HID technology also produces increased light output. A 35W Xenon HID lamp will produce approximately double the light of a 55W halogen bulb. Furthermore, HID technology will draw less power than a 55W halogen bulb from your vehicle's electrical system.
HID Color Temperature Explained
Color Temperature is a measurement in Degrees Kelvin that indicates the hue of a specific type of light source. Many people believe the misconception that color temperature is a rating of the brightness of the bulb or HID kit. This belief is completely false. The reality of the matter is that the higher the color temperature, the less useable light output you will obtain. A perfect example would be a black light. This light has a color temperature of approx 12,000k and has almost no usable light or lumen output. (http://www.kbcarstuff.com/HID_Kits_H...2001_s/216.htm)
