Those with TSX Retrofits, please read
stock tsx > stock fx low beam
modded afs/nonafs rx330 > stock tsx
modded fx > stock tsx
you custommake your brackets. They don't come already prefabricated. Some of you have halogen projectors and when swapped with xenon projectors, you end up molesting the stock brackets by alot or if you don't, then it is completely misaligned.
There are prefabricated brackets. There are a couple of people and one company who sells them (for the SC anyways). You're supposed to custom make the brackets but why hassle if you can make it a bolt on job with some cheap brackets. I'm actually contemplating doing a TSX retro (with cheap bracket) or trying to do a hybrid RX on my own. And are you the same striker that was arguing in my thread about my SC430/ES350 projector on hidplanet.
Custom fab indeed is doable, but didn't want any rooms for mistakes and thought it would be much easier this way and i've always read good reviews from tsx retro's either way.
Because you can make cheap ones from an aluminum sheet and metal scissors
Yes, I am the same old smartass
Sorry, but that other guy just tends to make himself god only because he's been a member before me and a few others.
To answer the OP's main question, the fact that your foreground limiter(which the tsx do not have but it's somehow there) is hitting the bottom reflector, it will be insignificant. Here's an example:
My apologies for the dirty headlight. It's been a cruel winter
![](http://i214.photobucket.com/albums/cc272/striker_1818/IMAGE022.jpg)
Beam at 10ft
![](http://i214.photobucket.com/albums/cc272/striker_1818/LHD-1.jpg)
![](http://i214.photobucket.com/albums/cc272/striker_1818/IMAGE_111.jpg)
Beam at 15ft:
![](http://i214.photobucket.com/albums/cc272/striker_1818/IMAGE_010.jpg)
Beam at 30ft
![](http://i214.photobucket.com/albums/cc272/striker_1818/IMAGE_079.jpg)
Beam at 40ft
Beam at 10ft
Beam at 15ft:
Beam at 30ft
Beam at 40ft
![](http://i214.photobucket.com/albums/cc272/striker_1818/IMAGE_040.jpg)
djkevin510
SC- 1st Gen (1992-2000)
03-02-09 04:42 AM
Billy305
12
10-24-07 12:46 PM
