Guess what i got for $129 =]
Find the clubaristo write up with PDF files for the q45 projectors, and then machine those pieces to be bolt on. Instead of cutting out the middle/mounts for the Q45, pull apart your projectors, and take the shield mounting holes and make it work for the machined pieces. No need to cut up bowls, and as long as you cut out the hole for the projector on the plate right, it'll line up perfectly, AND it will retain all the stock auto leveling/leveling screws for the headlights.
If you can't find the link, I'll post it when I get home, I don't have it at work.
