HIDEXTRA.com HID Review
#331
Former Sponsor
Hi,
Our colors only go up to 12K which is blue blue (Dark blue) unfortunately we don't have pictures of those, if you get all the beams, low , high and fogs,
you may want to purcahse a relay for the high beam 9005, since you are converting 3 lights to HIDs you want to at least power up one set of HIDs from the battery to help offset the power load from the original car connector.
Thanks!
michelle
Thanks!
michelle
Hi Michelle,
I would like to make sure the Kevlin before i place the order. Please kindly refer to the link below to your website -
http://www.hidextra.com/HID+Conversi...rsion+Kit.html
I got 2008 IS250 (With halogen capsule headlamps)
So i will need the following -
H11 Low Beams, 9005 High Beams, 9006 Fog Light am i correct? do i need relay for any of them?
Base on the link above the Kevlin indicate 10000K is Diamond Blue and 13000K is Deep Blue. I thought 10000K is Deep Blue. Do you have any images for show the Kelvin between 10000K and 13000K? when i try to pick the 13000K there is not available, only 12000K available.
You answer would be much appreciated!!
Thanks a lot!
Thanks a lot!
#333
Former Sponsor
Thanks Above for all the nice feedback and support!
For those of you wanting to get the same Spring special you can refer to the thread below to get the $58/kit special
https://www.clublexus.com/forums/clu...15-2010-a.html
Thank you!
michelle
Thank you!
michelle
#339
Former Sponsor
Looks like you need 4 H7 bulbs so that's 2 auto HID kits
see below link
http://starrotors.com/bulbs/motoappguide.htm
If you want to order, you can follow below to order your 2 H7 kits
2.) Then go to www.hidextra.com and choose the (BULB TYPE AND COLOR)
3.) Use Express checkout
4.) Input coupon code: springsp-m to get $17 off the kit price
Input coupon code: tenpercentoff-m to get 10% off bulbs only, ballast or accessories
5.) IF you are purchasing more than one kit, please do SEPARATE transactions for EACH kit in order to get discount on all kits.
Any questions, please email me @ info@hidextra.com
MIchelle
Hidextra.com
info@hidextra.com
860-821-8212
see below link
MIchelle
Hidextra.com
info@hidextra.com
860-821-8212
#340
the HID ballast is the same for the fog light 9006 and the low beam H11 Hid ? if so i want to order a pair to change out out one low beam and one fog light ? let me know thanks.. oh and i think of of the ballast on my fog is dead, just order 5k fog , installed and didnt work, and i did switched the bulb...
#342
Former Sponsor
Hi,
Yes the ballasts are the same so if you want another bulb type or color, all you need is purchase additional bulbs.
Email me to info@hidextra.com the order # of your defective ballast and I'll reply with instructions on how to get a replacement thanks!
Michelle
Also,
Michelle
Also,
#345
I love the way your lights came out, Ryan78. You got DRL, fogs and lows, right? What did you get specifically, I'd like to copy you! Do all of the lights match?
