HIDEXTRA.com HID Review
#751
But I ordered from the BF. I received the HID kit and wrong color bulbs and one side started flicker but after awhile it went away, I sent them a email and received new bulbs a few days later. One bulb ended up being the correct color (5000k white) While the other one is blue. I might contact them once again to fix it.
#752
I ordered three kits from the black friday sale. Althought it did take about 2+weeks to receive them, I remained positive. One midslim kit was installed with no issues (yet, as of today) other than them not being anywhere near crystal white and a second was installed on my car with the 3000K bulbs showing only green. One of those regular ballasts randomly stopped working. I swapped the ballasts and the bulbs were turning on. Results, one bad ballast in a few days period from being installed. I went ahead and checked the third kit' ballasts while i was at it and thankfully they did turn on properly. So,as of today;
Three kits (1-mid slim, 2 regular)
1-dead regular ballast
5000K bulbs are way too blue and seem closer to 8000K.
3000K bulbs are NOT yellow/orange. They continuously appear as neon green or of that sort.
I will be submitting a warranty claim shortly. I REALLY hope that the opposite ballast does not go awry when the new one arrives. (fingers crossed)
Cheers!
Cheers!
#753
i ordered a set of hid kit from them on BLACK FRIDAY and i have a problem with one of the bulb. So i called and emailed them for a warranty claim. i ordered a 6k and it actually turn out to be 8k, looked like blue than white. received a new set of bulbs within 4 days and finally got it to work correctly. this set of bulbs is actually 6k and is white.
I have nothing bad to say about hidextra, there service is great but there stuff is cheap and is made in china. i like my parts to be correct the first time and not have to go through issue like this. i will not purchase anything from them again.
for low budget people, i recommend hidextra if you don't want to shell out more than $50 for a hid kit.
nothing against hidextra.com
sometime you pay what you get..........just saying.
#754
Seems like every single page of this thread includes a horror story of something failing within a year or the color not being right.
Anyone have any actual success with hidextra?
I have seen dozens of competitors, but most of them just offer the universal spade connector to plug into the oem bulb socket - then they want you to use 5 feet of electrical tape and hope it never wiggles loose or gets contaminated with water, etc.
hidextra is one of the only ones that I have found to include the oem style connector so it just plugs right in and is safe/secure.
Anyone have any success stories out there or suggest a better company?
Also, who has current coupon codes??
#755
Former Sponsor
Hello,
We are truly sorry for the inconvenience. Please know our warranty covers 1 year after the purchase date. And if you have issues on your kit, Please email help@hidsupport.com it automatically directs to our RMA Department.
And please know we have a 2012 SALE on going,
25% off $49.99 or more (COUPON CODE: 25%2012)
30% off $79.99 or more (COUPON CODE: 30%2012)
40% off $149.99 or more (COUPON CODE: 40%2012)
PROMO STARTS 1.23.2012 -1.31.2012
![](http://www.hidextra.com/images/2012%20sale_banner.jpg)
#757
UPDATE: So someone finally pointed out that my passenger fog light was more white than my 6000K driver side foglight. I always thought that it wasn't the same color since the day I installed them, but I thought I was seeing things. Is there anyway that you can send me a 6000K bulb?
#759
Former Sponsor
Hello,
Please send us a picture of the bulb color at night so we can see the color clearly, sounds like you have a mismatch between the bulb color,
and once we receive the picture we will request replacement bulb to be send out to you for the color mismatch issue.
Please send it to help@hidsupport.com
Thank You
Thank You
#761
Last week my passenger side h3 slim fog setup stopped working all together. I've had issues in the past where it would randomly go out but if I jiggled the wiring it would come back on. This leads me to think that the ballast may have been on the fritz for a while.
I also have a low beam setup and when both fogs and low beams are turned on you can hear 3 ballasts firing up and get warm to the touch but the one in question makes no noise and stays cold.
I know the first thing to do is swap ballasts and see if the problem moves to the other side but for what it's worth i'll just say it will be easier to try a replacement ballast. I had a shop install both setups and getting to the working driver side ballast will require me to most likely remove the bumper to swap them out. Luckily the passenger side won't be as hard to replace.
Will I have any issue using a replacement slim ballast with a 2+ year old kit? Will the ballast be any different from the one i'm using? Does it include the inverter? Looking at my kit the inverter plugs in separately to the ballast.
![](http://i39.tinypic.com/21jnerb.jpg)
![](http://i44.tinypic.com/2ed48c5.jpg)
![Mad](https://www.clublexus.com/forums/images/smilies/mad.gif)
#762
Former Sponsor
Hello,
Thank you for all the information. Please forward your email to help@hidsupport.com. It automatically directs to our RMA department which they're the one sending replacements. And please provide the ff information in your email,
Name on the order:
Shipping address:
Contact information:
Date of purchase:
Order Number:
Thank you.
Name on the order:
Shipping address:
Date of purchase:
Order Number:
Thank you.
#764
Former Sponsor
