Auto Leveling
Auto Leveling
Ok guys after about 2 days of searching I still couldn't find anything regarding this. I changed my HID blubs about 3 days ago. At first they both did the auto leveling thing went down, up than back down. But they were high so I did a search and manually adjusted them down. They are both now level but only the Passenger side do the auto leveling and Driver side doesn't. I can adjust the passenger side lower and the driver side is stuck where it's at it will go up but not any lower. I looked at the bubble and Driver side is in the range but the bubble on the passenger side is all the way down (towards the front of the car).
No warning lights on dash. I'm lowered with H&R springs I think its 1.4 all the way around. Thanks
I just adjusted my ride height sensor yesterday and it's working for me. Before the lights were too high even with the adjustment in the front. Now it giving me enough light on the ground but I would need to adjust it higher in thefront becuase I freeway drive alot I need that long range of light. As for the auto levelers, I haven't check if they are working properly. Ok enough with my story. Now how high did you move your height sensor? Judging by the middle it should go up no more than half the siZe of the nut. And the rest u can just adjust it in the front. Gl
