License Plate Light SC 1st gen help!
So after spending countless hours doing searches and reading I was not able to avoid making a thread. I'll try to keep it short and simple.
Basically my light on the license plate was out, I got good info from search results on here at Clublexus.com. Saw some pics, read what size color and this and that about license plate lights. So I went out, got me some nice bulbs, replaced the old ones, I even clear/clean the plastic covers that had some dirt build up to them. Anyways, here I am still searching for a DIY on how to fix the License PLate Lights if they dont actually Light up.
So my question is, How would I fix my License Plate Light if they are not working after getting new bulbs?
Well I took out the 3 F'ing screws out using pressure pliers since I ran the ridges trying to unscrew them.
I had never seen the assembly before, so the left side of the light fixture is shorter than the right side, so I guess it is broken?
Cause it seems to me that it should be a single piece? Could anyone answer me this?
So to test the assembly I took out the door's light bulb out since they are the same that go in the license plate,
the right bulb lights up and the left side does not.
Since I don't know how to fix that, I am in search of a License Plate Light Assembly...
