Headlight help
Former Sponsor
Sounds like you over adjusted and popped the adjuster screw out of the clips.
If you remove the headlight from the car, you might be able to open the rear cover, pull the reflector bowl back with your hands and try to rescrew the adjusting screw into the clip.
Righty tighty, lefty loosie
