New HID bulb Flickers, turns off? Possible problem?
I just installed some brand new Garax HID 6000k DS4 bulbs. No I did not touch them with my fingers. I took great care to install them.
After about 5 hours of use over 2 days one of the bulbs started to flicker and went out. Turned the headlights off for 5 seconds and turned them back on and there would be no problem for 5-10 seconds. Then it would flicker and go out again. This happened 3 times on my way home from work. Next day is fine. Next day is fine again.
Should I ask for a warranty replacement since I just purchased these? Or...am i just over worrying?
Thanks in advance.
Thanks in advance.
That's a bit discouraging, especially after hearing so many good things about the Garax bulbs. Where did you get your pair from? Please keep us up to date when you get your replacements. Best of luck.
I have the same problem with my Philips D4S bulbs. Before changing the bulbs, the problem was with the left one. Now, both of them flicker, but the right one keeps turning off. Any ideas to where the problem is?
lex430drvr
03-08-12 07:09 PM
