35w or 55w HID kit?
35w or 55w HID kit?
So I have a 35w 6kk in my fogs and want to get the 5kk upstairs for the low beam. Should I go with 35w or the 55w for the low beam? What do you think, would I be ok without running the harness for 55w kit? Is the 55w going to be overkill and do you think the 35w will do the job fine? Any pics of a 35w vs. 55w would be really helpful. Thank y'all
So I have a 35w 6kk in my yellow fog lights and want to get the 5kk upstairs for the low beam. Should I go with 35w or the 55w for the low beam? What do you think, would I be ok without running the harness for 55w kit? Is the 55w hid kits going to be overkill and do you think the 35w will do the job fine? Any pics of a 35w vs. 55w would be really helpful. Thank y'all
i run the 55w upstairs and downstairs.
it runs the same voltage as the 35w during driving, so no need to worry about a harness or melting.
start up is 2 volts higher, still in a safe range.
OE hid is 55w, most aftermarket kits are 35w since 35w ballast and bulbs are cheaper
than 55w. According to some of the hid vendors, 35w hid kit is no more than 15% less
brightness than the 55w kit. ( I forgot which vendor it was, I read about this long time ago )
xsohaib
04-12-09 08:49 PM
