LEDs & HIDs! just random pics of stuff i installed
forgot to mention this to noe1988......98% of the lights i installed were very easy to do it's as simple as swapping them out. it's that 2% that gets a little tricky. you have to take everything apart and sometimes modify the housing or assembly and to top it off you have to de-solder the old bulbs to remove them and solder the new ones in. if you decide to do it i wish you luck. it takes time and patience.....2 things i seriously lack!
i added LED lights to the cupholders. i did it just for the fun of it after i saw pics of somebody's mod on another forum. was rather easy to do............the whole catch is i'm not sure if i like them.
look closely and you'll see them!
here's a pic with no flash, no lights, no nothing.
cool man!! please post pics when you do yours.
if you look at how mine are installed you'll notice that the lights are directed towards the inside of the cupholders and are barely noticable unless you are seated in the front and actually looking at the cupholders.
another note......i changed the position of them. i took them out and sealed the holes with JB-Weld then put them in the same spots on the other side.
footwell lights involved soldering. i basically swapped out the LEDs that were already in place(the stock ones are rather dull and boring). the running board lights are very easy to do. that's just swapping out the incandescent bulbs with LED ones.
SoKali-RX
09-16-22 04:32 PM
