Type of Relay Harness Problem
I currently have H11 HID kit from ddm tuning and want to buy a relay harness. Some websites such as HIDEXTRA and DDM tuning have generic relay harness and I was wondering if those will work with the kit that I have right now without splicing or looking for adapters! I am confused because on the xenondepot website, they have an option to choose the specific type of relay harness for different bulb types. Thanks!
Royale with cheese
i have a xenondepot one that came with my kit. it's plug and play if that means anything. no splicing.
the harnesses don't plug directly into the bulbs so generic should be ok. i think you should stick to ddm tuning harness since that's what kit you use. although the xenondepot ones are really well made. separate harnesses for each side and waterproof.
Former Sponsor
You get two harnesses with our relay harness - 1 harness per side. This way, if a fuse/relay ever goes out on you only one side gets effected. Our wire harnesses will come with proper H11 connectors that will plug into your OEM headlight wiring. We do not just give you generic spade terminals.
Steve
Steve
