02' ES Headlight help
Does anyone happen to know how the entire headlight fixture comes out? It kinda looks like you have to take the front bumper off, but I'm not too sure. It was hard enough to remove the rubber gasket and the wire held by a screw (which is removed now). Since it is phsicaly impossible to replace the screw with the wire without remove the fixture, the headlight beams are a little out of alignment, which is killing me! I need help!
