ldc Quote:
Originally Posted by rselby
I have put some HID 9006 in my fog lights on my 07 is350...no problems at all...all plug n play..hid extra, bulbs n ballast 6k
I'm waiting for mine, did you disconnect the battery to do the fog conversion?
no I did not disconnect the battery...made sure I had the lights off...was all plug n play very easy once u got to the OEM fog light
Ok my 9006 has just arrived. I'm abit nervous about it all cos foglights are lower to the ground and will be water hazadous.
mine has gotten wet..still going...I just zip tied them to the brake ducts...u prob dont have them to do that...but just get them up as high as u can, they can get a lil wet and still function...just dont submerge them!
Probably best to remove the bumper to install but what if you need to change the wiring or something and need access to the ballasts...have to take the bumpter off
Removing the bumper gave me lots of room to properly mount the ballast and run the wiring for the HID lights. Another way that I have seen to mount the ballast on the IS350 is to remove the wheel, peel back the fender lining and tape the ballast to the inside of the bumper.
I just wanted the peace of mind knowing that the ballast was in a secure location. Removing and reinstalling the bumper isn't that hard. The whole process only took about an hour. Hopefully I will never have to access the ballast or wiring again.
Originally Posted by ldc
Whatcha talking bout? the fogs are at the front and the battery is at the back of the engine
The OP has an RX350, which has a different battery location than the IS350.
