How to replace lights for 1997 SC300
foglights are a pain to get to. To make your life easy, you gotta take off the wheel and than take off the guard. theres two screws. once u take that off you can access the foglights.
the license plate lights are easy on the other hand. make sure your lights are off as u replace these because these lights can be extremely hot. All u have to do is un screw the cover right above the plate an pull the directly downward. u might have to yank it off. after that just slide your bulb in and your good
